ducatipaso.org • View topic - 907ie Hoses
It is currently Thu Apr 30, 2026 9:56 am
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: 907ie Hoses
PostPosted: Fri Feb 27, 2009 11:58 am
Does it help with the hose situation tho?
PostPosted: Fri Feb 27, 2009 1:49 pm
Soz ........yes am trying to put a set together.
PostPosted: Fri Feb 27, 2009 4:04 pm
i just tried it and it says damaged??? friday 2/27/2009
doug
1992 907ie #1473 Nero SOLD
PostPosted: Fri Feb 27, 2009 7:20 pm
works perfectly, I`ve added it to the downloads
(if anyone has problems he can try to download it from here)
http://www.box.net/shared/ou0yii8jnc
PostPosted: Sat Feb 28, 2009 3:57 am
I have the original link to this modification in the 907IE Tech section. Like I said, this eliminates one of the T-hoses, but there is still the junction on the left side to deal with.
Art
PostPosted: Sat Apr 11, 2009 3:57 am
Getting back to the original question, the 851 and most other Duc radiators have their inlet and outlet on the left side, the Paso inlet is on the right so the upper hose with the T in it won't work. The 4 hose junction on the Paso is available, but the thermostat is not. The closest bypass style thermosat available is the 996/ST2/ST4 model with the top outlet in the opposite direction. To mount it would require changing it's orientation to be like the 996 and to use the junction block from a 996. The hoses to the upper radiator and water pump would need to be customized. Let me know if anyone has other suggestions. My thermosat was leaking, but rather than changing the set-up now that riding season is here, I opted to repair it. I cut the metal band with a dremel tool and removed it, separated the thermostat housing enough to silicon the joint, and put the band and a clamp back on it.
PostPosted: Sat Apr 11, 2009 11:46 am
I will have a look at a few car type hose links later to see if there are any that fit.
PostPosted: Wed Apr 15, 2009 1:32 am
The radiator and water pump connections are 1" or 25 mm. The smaller hose fittings to the heads measure .835", so the hose needs to be 19 mm I think? Not exactly automotive sizes. Got any links to recreational vehicle hose catalogs?
PostPosted: Wed Aug 05, 2009 2:27 pm
Some KTM hoses look like they might fit the paso.
As for the thermostat, I used an aprillia 1000 thermostat with a cut down 90 degree silicone hose and a link pipe.
907IE
Paso 750
CB 900FD
KX 500
KTM 500 with Zabel 700 Engine
zx10
Mobylette Cady
