It is currently Tue Apr 28, 2026 6:01 pm
| Author |
jcslocum
Post subject: Re: 907ie Hoses Posted: Fri Feb 27, 2009 11:58 am |
| paso grand pooh-bah |
Does it help with the hose situation tho?
| Top |
englishstiv
Post subject: Re: 907ie Hoses Posted: Fri Feb 27, 2009 1:49 pm |
Joined: Wed Apr 09, 2008 9:57 pm Posts: 1097 Location: Manchester, England.
Soz ........yes am trying to put a set together.
_________________ DUCATI 907ie STIMSON SCORCHER 3 WHEELER CZ 175 Sport.
| Top |
Stingray230SX
Post subject: Re: 907ie Hoses Posted: Fri Feb 27, 2009 4:04 pm |
Joined: Fri Jul 16, 2004 12:00 am Posts: 202 Location: USA
i just tried it and it says damaged??? friday 2/27/2009
doug
_________________ 1992 907ie #1473 Nero SOLD 1997 Vmax Nero-Blue Flames SOLD
| Top |
Shelboss
Post subject: Re: 907ie Hoses Posted: Sat Feb 28, 2009 3:57 am |
Joined: Wed Sep 06, 2006 12:00 am Posts: 101 Location: USA
I have the original link to this modification in the 907IE Tech section. Like I said, this eliminates one of the T-hoses, but there is still the junction on the left side to deal with. Art
| Top |
Shelboss
Post subject: Re: 907ie Hoses Posted: Sat Apr 11, 2009 3:57 am |
Getting back to the original question, the 851 and most other Duc radiators have their inlet and outlet on the left side, the Paso inlet is on the right so the upper hose with the T in it won't work. The 4 hose junction on the Paso is available, but the thermostat is not. The closest bypass style thermosat available is the 996/ST2/ST4 model with the top outlet in the opposite direction. To mount it would require changing it's orientation to be like the 996 and to use the junction block from a 996. The hoses to the upper radiator and water pump would need to be customized. Let me know if anyone has other suggestions. My thermosat was leaking, but rather than changing the set-up now that riding season is here, I opted to repair it. I cut the metal band with a dremel tool and removed it, separated the thermostat housing enough to silicon the joint, and put the band and a clamp back on it.
| Top |
englishstiv
Post subject: Re: 907ie Hoses Posted: Sat Apr 11, 2009 11:46 am |
I will have a look at a few car type hose links later to see if there are any that fit.
| Top |
Shelboss
Post subject: Re: 907ie Hoses Posted: Wed Apr 15, 2009 1:32 am |
The radiator and water pump connections are 1" or 25 mm. The smaller hose fittings to the heads measure .835", so the hose needs to be 19 mm I think? Not exactly automotive sizes. Got any links to recreational vehicle hose catalogs?
| Top |
riascns
Post subject: Re: 907ie Hoses Posted: Wed Aug 05, 2009 2:27 pm |
Joined: Wed Aug 05, 2009 2:02 pm Posts: 84 Location: London, UK
Some KTM hoses look like they might fit the paso.
As for the thermostat, I used an aprillia 1000 thermostat with a cut down 90 degree silicone hose and a link pipe.
_________________ 907IE Paso 750 CB 900FD KX 500 KTM 500 with Zabel 700 Engine zx10 Mobylette Cady
| Top |
Users browsing this forum: No registered users and 11 guests |
