| It is currently Fri Jun 19, 2026 11:16 am |
[ 10 posts ] |
| Author | Message | |||
| Ducati Dennis |
| Top | ||||
| higgy |
Joined: Tue Jul 29, 2008 9:50 pm Posts: 3259 Location: Hilltown,Pennsylvania model: 906 Paso year: 1990 |
| Top | ||||||
| Tamburinifan |
Joined: Thu Jun 21, 2007 12:00 am Posts: 1501 Location: Gothenburg, SWEDEN model: 907 I.E. year: 1991 |
| Top | |||||
| Ducati Dennis |
| Top | ||||
| Brutus |
Joined: Sun Jan 16, 2005 12:00 am Posts: 257 Location: The Netherlands model: 750 Paso year: 1989 |
| Top | |||||
| Ducati Dennis |
| Top | ||||
| jcslocum |
Joined: Mon Jul 19, 2004 12:00 am Posts: 1714 Location: Eastern Shore, MD model: 750 Paso year: 1988 |
| Top | ||||||
| Ducati Dennis |
| Top | ||||
| Tamburinifan |
| Top | |||||
| jcslocum |
| Top | ||||||
[ 10 posts ] |
Users browsing this forum: No registered users and 10 guests |
| You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum |
Is there some kind of locking device, a key, or something I am missing? I also need to remove the timing control pulleys but do not have the tool, anyone know a way around this? Thanks
Well it is and a few light taps freed the crank from the housing, and all the ball bearings on the lower side. After panicking to try to save them all, then removing the remaining, I now have a loose crankshaft rod through the hole with a stubborn gear still attached!
I have found a new set of cases, they seem to match nicely with the old set. Any thoughts on simply using one old with one new? I know, I know pretty weak idea, but everything internally is fine, only destroyed the alt cover and the right case when the chain/gear failed. I can provide pics or you can see them on facebook under "dennisofthebeach". Thanks again!
