ducatipaso.org • View topic - Separation issue
It is currently Mon Apr 27, 2026 1:55 am
 Post subject: Separation issue
PostPosted: Mon Mar 23, 2009 12:49 am
Sorry, bike related... ;)
Want to overhaul my clutch master reservoir and found the idle lever attached to it.
How do I separate them?
No screws visible or are they hidden?
 Post subject: Re: Separation issue
PostPosted: Tue Mar 24, 2009 12:14 am
Found out myself :wink: :
You loosen the reservoir, move the idle lever so it slips out of its seat
and then you`ll see the screws f the idle assy to be removed from clutch reservoir.
PostPosted: Tue Mar 24, 2009 1:28 am
Well done Gert.
The trick is getting it all back in place again.
Good luck.
:banghead:
Jaffa
'91 907ie (RED)
'82 900 Mike Hailwood Replica
Volvo aware Motorcyclist
PostPosted: Tue Mar 24, 2009 11:47 am
Yup,
and first to get the reservior repair kit in first.... :banghead: :banghead:
PostPosted: Wed Apr 08, 2009 5:21 pm
A bit tricky and not so few :twisted: :banghead: words.
(Also, reservoir had to be worked over abit to make the repair kit work. :mad:)
The idle lever cover loosens when positioned halfways over piston/
dust cover in reservoir.
And of course reassembles in very same position, dust cover/piston must be compressed a bit.
The wire mount hole towards el controls is the one to use, why there is another, who knows...
All easier if wire loosened at TB`s.
So now, :beer: .
PostPosted: Wed Apr 08, 2009 5:35 pm
Did You get repair kit ??? From where??? What price?
Dont :beer: too much! I have done it sometimes and suffered about 4 days from it... Cant eat anything for 2 first days... then little by little same time quessing, does all come out very fastly, or after some minutes... :mrgreen:
PostPosted: Wed Apr 08, 2009 5:41 pm
Kit from Bevelheaven, look f Brake rel parts-Brembo, 25,50 US$.
Think Yoyodyne also has.
I only drink Danish green Carlsberg, not a big bottle of Kosken in a sauna
so I`m usually OK. :lol:
But more work would be done without the beer, that`s for sure... :thumbup:
