It is currently Tue Sep 30, 2025 7:42 am
[ 5 posts ] |
Author |
ltbauzo
Post subject: Problems starting my 907ie Posted: Mon Mar 23, 2009 10:47 am |
Joined: Thu Jan 29, 2009 1:51 pm Posts: 4 Location: Piacenza, Italy - London, England
Hi all,
my 907ie is apparently dead...yesterday I went to start it and had no luck.
It was used last time only about three weeks ago. The funny thing about yesterday is that while the speedo was illuminated correctly and the clock kept working while I was trying to start the engine they did not seem to be affected by the start engine being engaged.
When I pressed the start button all I got was a one of two "ticks" from down below. As I said the lights did not dim or anything (I kept them on to check all was normal). I then connected the battery to my car with some jump leads and - to my surprise - I got the same result..
I suspect (and hope) it is only the battery that is shagged.
Anyone got any ideas? Many thanks.
Cheers, ltbauzo.
Top |
jcslocum
Post subject: Re: Problems starting my 907ie Posted: Mon Mar 23, 2009 11:15 am |
paso grand pooh-bah |
It does sound like the relay (starter solenoid) that =switches the 12v to the starter. If the lights don't dim when pressing the button then it seems like no power is going to the starter.
You can "jump" the solenoid with a pair of pliers or a jumper cable to see if the starter turns over. Just make sure that you have the trans in NEUTRAL!!
Top |
ducbertus
Post subject: Re: Problems starting my 907ie Posted: Mon Mar 23, 2009 11:57 am |
Joined: Sun Jan 07, 2007 12:00 am Posts: 531 Location: holland
hi, sounds like the starter relais.the leads going to and coming from the starter relay have rubber sockets (most of the time) over the connectors. In my case one of them appeared to be mounted up side down and acting like a bathtup. needless to say the connector was corroded very badly. after cleaning the bike fired up much faster. I cured this by rerouting the wires. furthermore you can check the connectors for broken fibres of copper. this happened to me at the battery. half of the fibers were broken. putting the jump leads after the startersolenoid will tell the tale.
ducbertus
Top |
persempre907
Post subject: Re: Problems starting my 907ie Posted: Mon Mar 23, 2009 6:15 pm |
Joined: Tue Dec 06, 2005 12:00 am Posts: 3312 Location: Roma, Italia
If I've well understood, he heard some "tick" trying to start the bike. When I had a problem with the rusty connections on the relay, I couldn't hear any "tick" at all. No matter, try to clean very well the relay connections (it's under the main right fairing). Good luck.
_________________ Francesco Ducati 907IE 1992 Rosso Ducati 907IE 1993 Nero Moto Guzzi Galletto 1960 Sabbia BMW R Nine t 2019
Top |
[ 5 posts ] |
Users browsing this forum: No registered users and 103 guests |
