ducatipaso.org • View topic - How much is enough
It is currently Mon Sep 29, 2025 9:52 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: How much is enough
PostPosted: Mon Apr 06, 2009 9:50 am
Hi all,
I have just fitted new tyres to my 906 and I was after some advice on how much gap is enough ie:between tyre and cross piece in the swingarm and tyre and chain.The reason I'm asking is I don't want to fork out for a new chain if I don't have to.The rear cam adjuster is in the 6 o'clock position at present and there is a gap of approximately 4mm between the tyre and cross piece.With the chain,it is only just touching the tyre so I could turn the rear sprocket around to get about 3mm clearance.
These are the tyres I had fitted,
Front http://mc.bridgestone.co.jp/en/products ... bt014.html
Rear http://mc.bridgestone.co.jp/en/products ... .html#G704
Cheers Ken
 Post subject: Re: How much is enough
PostPosted: Mon Apr 06, 2009 5:50 pm
Can You add some fotos from Your bike? I mean just those parts, what You are talking about...
PostPosted: Tue Apr 07, 2009 1:01 am
Some photos
Cheers Ken
PostPosted: Tue Apr 07, 2009 1:17 am
That is one mighty clean Paso :thumbup:
PostPosted: Tue Apr 07, 2009 4:09 am
I tried turning the sprocket around to gain more clearance but this has been known to put unwanted stress on the bolts causing them to break. A better option is to get a spacer made up.
PostPosted: Tue Apr 07, 2009 4:59 am
Seems, that there is enough space between tire and swingarm...
btw, how and with what chemicals You polished those aluminium parts? It looks great! :thumbup:
PostPosted: Tue Apr 07, 2009 7:14 am
G'day Antti,
Thanks.Polishing those parts was a long,painful exercise which consisted of sanding all the anodising off the aluminium using 180,380,600 grit wet n dry.Then I used a high speed wax buff to bring it up to a mirror shine.During the whole process I lost several layers of skin off my fingers.
To keep it shiny I use a product called Purple Polish,so far the best polish that I've used.
http://www.calcustom.com.au
PostPosted: Tue Apr 07, 2009 4:30 pm
You need to be mindful of the chain running in a straight and true alignment with the 2 sprockets. Running them offset will give you problems.
The tire at the front cross section just doesn't have enough clearance. At speed the tire will grow in diameter and likely rub.
See this site for a mod that has been done:
http://paso.enthusiast.co.nz/
PostPosted: Tue Apr 07, 2009 5:40 pm
Great polishing work.
The result is really impressive.
Ciao :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
PostPosted: Fri Apr 10, 2009 4:24 am
The minimum clearance from the chain to the tire is 0. An occasional light rub between the two is not a problem. Chewing away rubber is a problem, but leaving marks on the edge of your tire is not. It is more important that your rear tire be pointed square in your swingarm.
PostPosted: Fri Apr 10, 2009 7:23 pm
Duc906: did U anything same time to front sprocket offset, as You "turned" rear sporcket??? I hope, that U changed also front sprocket offset same time.... :shock: If no, then Your chain line is very bad and it can make bad damages to chain and engine cases, if chain gets broken... :smoke:
PostPosted: Sat Apr 11, 2009 12:06 am
Slight thread-jack.
Another way to remove anodize from aluminum parts is to use high strength oven cleaner, and heat them up a bit. You may have some explaining to do to your wife why you are using gloves and baking you motorcycle parts in the oven, but it might be easier than trying to sand it all off.
PostPosted: Sat Apr 11, 2009 1:06 am
36 years ago I heated a cylinder head in my first wife's oven, She is now my ex wife and I have hot plate.A very good hot plate. It is 30 years old and still works great :thumbup: :beer: :beer:
PostPosted: Sat Apr 11, 2009 5:16 am
PostPosted: Sun Apr 12, 2009 7:14 am
200° celsius is enough, but the kitchen's oven might be seriously polluted by such a job...
Users browsing this forum: Google [Bot] and 31 guests
