ducatipaso.org • View topic - Oil leak near exhaustpipe
It is currently Mon Sep 29, 2025 8:33 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2, 3  Next
 Post subject: Oil leak near exhaustpipe
PostPosted: Thu Apr 09, 2009 6:34 am
Hi, both cylinderheads have a oil leak near the exhaustpipe. I have bin told to replace the o-rings.
Doe anybody have any pictures off the head\cylinder so i have a impression what i have to do?
Mayby some tips?
 Post subject: Re: Oil leak near exhaustpipe
PostPosted: Thu Apr 09, 2009 11:08 am
I guess what they mean are the O-rings on Tav.7 of the parts catalogue.
PostPosted: Thu Apr 09, 2009 7:04 pm
First before do anything more: retighten sylinder heads with right torque. If its leaking still after that, then its propably just those old o-rings in in water cooling lines and oil lines between head and sylinder... I have suffered same problems and it was in my case too old o-rings... :thumbup:
PostPosted: Fri Apr 10, 2009 11:23 am
This is what the (green) o-rings look like
Horizontal cylinder
vertical cylinder
as you can see, these were leaking as well.
PostPosted: Sun Apr 12, 2009 12:50 am
PostPosted: Sun Apr 12, 2009 7:27 am
I think you'd better have a look to the guide-valves and their sealing... A too leak gap in this part is the main cause of oil in the exaust
PostPosted: Sun Apr 12, 2009 8:00 am
cleaning the oil spill and keeping an eye on it would be the first thing to do to have a chance to see where the oil comes out. If its the valves covers it`s easy, if you have to remove the cylinder heads you can check and/or replace all gaskets while you`re at it.
PostPosted: Fri Apr 17, 2009 12:12 pm
Hi Guys,
I am 100 % sure the leak(s) are similar like the pictures off Duckboy. I tried to retighten the cylinders but that did not helped. The pictures are very helpfull, THNX!!
Soon i will take off both heads & replace the o-rings. First I am going to enjoy my leaking Bike during this lovely weather!
Greetings,
Erik
PostPosted: Fri Apr 17, 2009 1:00 pm
Hi Erik
while you have the heads off, don't forget to replace the o-rings at the base of the cylinders (eg. between the cylinder and the crankcases, and the base cylinder gaskets as well.)
PostPosted: Fri Apr 17, 2009 6:56 pm
Some advice still: those o-rings MUST be VITON (FPM) material, NOT normal o-rings !!! :thumbup: Sometimes no need to change gasgets between sylinder and case, IF You managed take heads out very carefully without moving sylinders, but You have to be very carefull. I do such last time and no any leak between sylinders and cases... :thumbup:
PostPosted: Thu Aug 27, 2009 10:52 am
When I first bought my 906 with 17,000Km on the odometer, the Dealer told me he was surprised the heads weren't leaking and it was a common fault. He said it must have allready had the heads machined and new o rings fitted. Within 2,000km it started leaking. I thought he must have loosened the head nuts! I have replaced the o rings and it did not help so maybe he was right about machining.
Brake late & brake hard,
jomo
Paso 906 Blue
Paso 906 Silver
Bultaco Metralla GT370 Custom
Bultaco Metralla GT250
Bultaco Frontera 250 Mk.9
Suzuki RMX250
PostPosted: Fri Aug 28, 2009 7:05 pm
PostPosted: Fri Aug 28, 2009 8:26 pm
I would not machine any head or cylinder without checking it myself with a good straight edge and a reliable feeler gauge. also re-torque on a 20 year old viton o-ring is a waste of time
JM2C
PostPosted: Sat Aug 29, 2009 8:17 am
PostPosted: Sat Aug 29, 2009 11:26 am
Any time you take off a head it is a good idea to check the head and the cylinder to be sure it is true. A good straight edge only cost between 20 and 30 dollars(USD) in the size required.Feeler gauges are also relatively cheap as well. Also like stated earlier in this thread don't forget the o-rings under the cylinder.
If you do find you head is warped it is a much better idea to straighten it first and only as a last resort should you have it resurfaced. If the surface is out of true,then the cam bores are also out of alignment and this is much more critical than the gasket surface. Broken timing belts are much worse than any annoying oil or coolant leak. :thumbup: Straightening a head is a little more involved
(meaning more money) than machining but not difficult. You do need a steel plate that is true(flat= big dinero :( ) and large enough to take the strain of torquing the head to it and heating the whole assembly in an oven to 425F(218C) then letting it cool slowly and rechecking it for trueness and repeating the process till it is true By the way you don't want to do this in any oven that is used for cooking :lol:
Hope this helps and just let me know if you need more detailed info
PS: Gert,the heads are resurfaced across the entire gasket surface if the surface is pitted or has low spots and even then the proper way to do it is to add metal to the low spots by welding AFTER the heads have been straightened by heating and torquing to a flat plate and then machining the welds to match the rest of the surface. IT IS NEVER A GOOD IDEA TO REMOVE METAL FROM ANY HEAD
