ducatipaso.org • View topic - How much is enough
It is currently Mon Sep 29, 2025 7:07 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
 Post subject: Re: How much is enough
PostPosted: Sun Apr 12, 2009 12:30 pm
DUC906,
Where did you get that roll around thing the bike is on??
PostPosted: Wed Apr 15, 2009 9:43 pm
PostPosted: Thu Apr 16, 2009 12:53 am
PostPosted: Thu Apr 16, 2009 7:40 am
PostPosted: Thu Apr 16, 2009 10:15 am
PostPosted: Thu Apr 16, 2009 11:02 am
did you fix the rear end of the swingarm with a large spacer while doing that ? I would be afraid that the swingarm ends would move inwards when applying pressure to the middle section.
PostPosted: Thu Apr 16, 2009 12:03 pm
PostPosted: Thu Apr 16, 2009 12:18 pm
PostPosted: Thu Apr 16, 2009 1:07 pm
re: roll-around thingy:
here's a side-stand variant for $100.
http://www.harborfreight.com/cpi/ctaf/d ... mber=95896
- Kurt
PostPosted: Sun Feb 07, 2010 4:48 pm
thanks for the infos, i think i will also go for the conversion 180 / 60 16.
the advantage of that bridgestone tire is: it has only 179 mm widenness (Avon: 182, Dunlop: 183)
disadvantages: as far as a know, it is made for the front wheel (!) of a goldwing
just a simple question in regarding the clearance to the swingarm (front):
moving the excenter to, e.g, 4 clock position should give you some extra space. you may have less
adjustment possibilities for the chain but before making changes on a producation part of the paso, I would rather
try this.
am I wrong?
thanks for your answer, hardo
PostPosted: Sun Feb 07, 2010 5:11 pm
1,5mm per side don`t make a huge difference therefore I`d recommend the Avon. You should make up your opinion after calling the tire manufacturers and hear what they say about using their model on a bike like the Paso
PostPosted: Sun Feb 07, 2010 6:02 pm
you are right, but i am afraid of the diameter size too: e.g., avon is 630, dunlop (D 250 F) only 615.
that is quite a difference and should help because there is very little space at the front of the tire / swingarm anyway.
to come back to the point with the excenter: is it a problem to go away from the 6 o'clock position in order to gain some additional space in the front (swingarm / tire)? am I thinking to simple?
PostPosted: Sun Feb 07, 2010 7:02 pm
no, it`s not a problem. To the front there`s enough clearance depending on excenter position with the Avon.
see here, I had made some pics:
viewtopic.php?f=1&t=3042&hilit=avon+av72&start=60
pasoalf (also from CH) is using a Avon Av72 also, see previous page in that thread
PostPosted: Sun Feb 07, 2010 7:06 pm
thanks a lot for the info!
some pictures would be great! :cool: hardo
PostPosted: Sun Feb 07, 2010 7:10 pm
have just edited the last post and added a link
