ducatipaso.org • View topic - best solution for the michelin problem
It is currently Wed Mar 11, 2026 7:35 pm
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
 Post subject: Re: best solution for the michelin problem
PostPosted: Sun Apr 05, 2009 4:35 pm
JWilliam, is that Your welded part(end od swingarm) same material, as swingarm, or some other material, like steel ?
PostPosted: Sun Apr 05, 2009 10:13 pm
Well its obviously the metal same as the swingarm, you can't weld steel to aluminium!
PostPosted: Mon Apr 06, 2009 5:29 pm
It lookeed different and thats why i asked :wink: I asked it also, cause totally different metals make corrosion, if they are welded together, but You can now sleep calmly... :thumbup: Btw, well done!
PostPosted: Fri Apr 17, 2009 3:15 am
