ducatipaso.org • View topic - New to the Forum, my first Ducati
It is currently Fri Apr 24, 2026 3:03 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
 Post subject: Re: New to the Forum, my first Ducati
PostPosted: Thu Apr 23, 2009 3:07 pm
some small notes:
Its not so bad idea to cheack immediatelly Your valve clearances and change belts, but if nothing serious cant be found, then i would say, that valves should be checked every 20 000kms(10 000km, what manual says is little too often). Belts change every 20 000kms or every 3 year(as manuals mentioned every 2. year is too often).
Fuel system needs attention: fuel filter change every 20 000kms !!! You should make big adjusting/maintain with TPS set, Syncronization, injector maintaining(need special store and tools), idle adjustment, etc IF such have never done to Your bike !!! One advice: change fuel filter from inside tank to outside, so its much easier to change, when needeed.... Put only suitable pipe inside tank to filters old place...
I have had only good result with Champion spark plugs and only bad from NGK.....
About valve adjustment: Do You know, what and how to do it? if no, then there are in internet many sites, where U can find how to do Ducati valve check. Its shown in newer ST workshop manuals also.
Do U know, how TIGHT/LOOSE those belts have to be? Its not only, are they looking good or bad...... Also about this thing You can find very good advices from internet and using 5mm and 6mm allen tools for "testing" is very used method and very(enough) accurate.... and simple!
:thumbup: :smoke:
PostPosted: Thu Apr 23, 2009 3:42 pm
I know how to do most of it, just nervous where it is a ducati.
The worst part is the closest shop is 4 hours away. So I need to do everything I can from home.
I do not know valve clearences, or belt tensions.
I do not know the bikes history. But it has been sitting for quite some time.
The bike has 50,000 miles on it.
What would a typical dealership cost to do a all around maintence checkup on the bike? Idea's?
George
PostPosted: Thu Apr 23, 2009 4:03 pm
I think, ONLY way to know, how much it will coast is to ask from such Ducati guy in Your country, who really knows about things.... I dont thrust so much those Ducati dealers, as i have seen, that thay lie, "what they have done to U bike" sometimes.... Or better say, what they HAVENT done! :smoke:
PostPosted: Thu Apr 23, 2009 4:08 pm
PostPosted: Thu Apr 23, 2009 6:50 pm
George have a look at this it's not exactly what you want but it may give you an idea and look at Jon's home page as there is lot's of info there under the maintenance section
http://www.ducatisuite.com/
http://www.youtube.com/watch?v=9vzPZ84ZRjU
and this
http://www.youtube.com/watch?v=dIj3nSJG ... re=related
or this
http://www.youtube.com/watch?v=3WQY1MRl ... re=related
What ever you do decide to do personally? ............I woulld CHANGE THOSE BELTS mate.
