ducatipaso.org • View topic - Clock disconnect
It is currently Fri May 01, 2026 2:23 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Clock disconnect
PostPosted: Tue Apr 14, 2009 7:52 pm
Yep, orange it is. No ill effects after cutting same. Now that I have an Odyssey battery, I have re-connected the clock, will see how it goes ...
- Kurt
PostPosted: Tue Apr 14, 2009 9:32 pm
so....now all ya gotta do is connect a switch between those sections of the wire and then you can turn it on/off at will huh? :wink: i like that idea......and dont ask me how i know but.....invest in a "GOOD" battery tender cause a cheap one will kill your battery :,(
doug(whose 907 is currently on the table for a few bits of work and will prob get this "orange' wire switch mod while the fairings are off)(and a new Odyssey PC535 battery)
1992 907ie #1473 Nero SOLD
PostPosted: Tue Apr 14, 2009 11:24 pm
PostPosted: Wed Apr 15, 2009 5:48 pm
I think there is only 2 possibilities with Ducati: You disconnect battery very often("clock taking current from battery"!), OR buy very good battery charger to keep battery allways up.... I use such battery charger and i change it from one Ducati to another every 1 week, or so..... no problems till battery life is at end... :smoke:
PostPosted: Sun Apr 26, 2009 12:27 am
Confirming that cutting orange lead to clock works w/o any other things happened.
PostPosted: Sun Apr 26, 2009 5:00 am
Wow! I must be incredibly lucky. I put a new battery on mine about 8 months ago and it sits sometimes for a week or over, no tender or nothing and it starts right up, no problems.
I really don't agree with the disconnecting of the clock, to me it's like amputating a finger because you have a nail problem or something like "the surgery was a success but the patient died" ... :smoke:
just my humble opinion, so whatever floats your boat ....laterzzzz
1992 Ducati 907 IE
1993 Ducati 750 SS
2006 Harley Davidson Sportster
2008 Harley Davidson ElectraGlide Classic
PostPosted: Sun Apr 26, 2009 9:09 am
Had some sprag problems so wanted to b sure of good juice fr battery.
Will get a switch f my clock as I miss it already.
PostPosted: Mon Apr 27, 2009 8:37 pm
PostPosted: Mon Apr 27, 2009 9:22 pm
I recently had a electrical issue with my 750SS that with the help of some forum members I was able to trace and repair myself (regulator). I learned quite a bit during that "event".
If I may suggest:
1- make sure you have a good battery, I mean a really good and appropiate battery to begin with.
2- inspect and re-inspect your wiring, especially the ground cables, plugs, splices, ect. (make sure they are tight and clean)
3- check the charging system (stator, regulator, ect.) for proper charge loaded and no-load.
I do this to my '92 907 and like said before it'll sit for a week or more and then starts immediately, no problems.
If I were to leave them sitting for a extended period of time (months) I would then disconnect the battery or consider a tender.
Maybe I'm a bit attached to the clock on my 907 as my other Duc doesn't have one and I miss it when riding the 750 :cool:
Hope this helps a bit!! :beer: :beer: :beer:
1992 Ducati 907 IE
1993 Ducati 750 SS
PostPosted: Mon Apr 27, 2009 9:25 pm
PostPosted: Tue Apr 28, 2009 1:06 pm
When I need to disconnect clock from battery (long stand-by ) I just unplug the related fuse
PostPosted: Tue Apr 28, 2009 8:37 pm
Is there a fuse only for the clock?
What is this?
PostPosted: Wed Apr 29, 2009 5:38 am
Not only for the clock, but when the bike is standing by in your garage...You don't need ignition or injection!
PostPosted: Thu Apr 30, 2009 7:50 pm
Nicola,
would you let us know what's the fuse???
I always disconnect the battery so that I can start the bikes when I want to have some little trip.
GRAZIE MILLE (Many thanks).
PostPosted: Fri May 01, 2009 10:26 am
Just turn on the main switch and disconnect each fuse until the clock stops! :D
