ducatipaso.org • View topic - 88 limited gearbox final drive noise?????
It is currently Thu Mar 05, 2026 7:48 am
Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2, 3  Next
 Post subject: 88 limited gearbox final drive noise?????
PostPosted: Sun Apr 26, 2009 7:56 pm
my limited has been giving me fits for awhile. symptoms as follows squeky noise at road speed (final drive output shaft speed???) it will make the noise with the clutch out but it gets worse when you hold the clutch in, I can repeat the noise on the center stand while I am right next to it and it sounds like its coming from the rear of the engine possibly from the final drive output shaft area but not 100 percent sure, its pretty loud, very annoying and gotta be leading to worse things down the road. any ideas?????
John
 Post subject: Re: 88 limited gearbox final drive noise?????
PostPosted: Sun Apr 26, 2009 8:33 pm
In recent posts I've mentioned the bronze bushing in the gearbox. It's in the second gear just next where the front sprocket is fitted. If this is the case, driving on can cause damage to the second gear. You should have noticed this while shifting gear (less smooth).
cheers! Léon
PostPosted: Mon Apr 27, 2009 3:09 pm
I havent experienced any problems shifting, just the noises. It sure sounds internal and unfortunatley I dont have the time or money to dive into this kind of a project, If I cant find a magic wand for this one the duck may have to go John
PostPosted: Mon Apr 27, 2009 8:51 pm
So, with the bike in gear, the rear brake on (wheel not turning) AND the clutch in, you get this noise??
Pull the clutch cover and look at the button and bearing.
PostPosted: Wed Apr 29, 2009 6:46 am
yes Im pretty sure it does although I cant remember if I tried that specifically. I recently installed a new clutch and everything seemed alright. I will open the clutch back up and check thinkgs out again. if I dont see anything obvious I will probably take it to one of the local ducati shops and see if they can bless or condemn my baby
PostPosted: Thu Apr 30, 2009 8:52 pm
PostPosted: Thu Apr 30, 2009 10:56 pm
PostPosted: Sat May 02, 2009 4:54 pm
OK its saturday morning and I pulled the Duck out of the garage for further trouble shooting. I opened up the clutch cover..... the button seems OK when I turn it it turns freely but it does feel a little gravely (if thats a real word) now when I put it back together and run it in gear it makes a little noise with the clutch out and a lot more noise with the clutch in..... if I put on the rear brake at this point to stop the rear wheel the noise stops. with body work off and my head down by the spinning parts it really sounds like its coming from the clutch, my next question is should the throwout bearing be glass smooth? it turns freely but also feels a little rough. At least I'm feeling more like this might be fixable and affordable.. thanks for all the help so far John
PostPosted: Sat May 02, 2009 11:38 pm
Thge bearing should be smooth as glass. No gravel or rough feeling to it at all. The button spins in it at engine spped so it can make plenty of noise. There should be info in the FAQ about the bearing (rollerskate) and seal. Not a hard fix at all. You definately want to get it fixed becasue the button is unobtanium.
PostPosted: Tue May 05, 2009 4:01 am
I got the bearing coming but cant quite figure out the seal, do you have that p.n. handy. also I assume to remove I just remove the clutch cover and start pumping the clutch intil it all pops out of the cover???? John
PostPosted: Wed May 06, 2009 5:41 am
Yes. Then clean it carefully and drain correctly
PostPosted: Fri May 08, 2009 1:12 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Fri May 08, 2009 6:43 pm
Info on the seal:
viewtopic.php?t=676
It's better to fix the slave before the pin is shot than find a place to make it.....
PostPosted: Sat May 09, 2009 7:33 pm
now for the 64K question I have everything apart to install the new bearing but........ how does the button come out of the bearing????? the bearing is pressed into the piston and it appears the button is pressed into the bearing, I cant see a way of getting the button off without damaging it. Is it possible that the button is just stuck from being in there so long???? should I soak it in something or just pry on it a little harder????? I know from previous postings that the button should be treated like a god....... any ideas????
PostPosted: Sat May 09, 2009 10:08 pm
It's a slight interference fit. Use some lube and just work it out.
Users browsing this forum: No registered users and 31 guests
