ducatipaso.org • View topic - manifold problems
It is currently Tue Sep 30, 2025 3:50 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
 Post subject: Re: manifold problems
PostPosted: Fri Apr 17, 2009 6:43 am
Crusher,
Try Grant at spares@ducatispares.co.nz or visit their site WWW.ducatispares.co.nz as they are wrecking several Ducatis (including a Paso) for another manifold. Or try Phil at Desmocycle (sorry can't find his email address). Always keep an eye out on TradeMe, as I've seen carbs & manifolds for sale (there is a Weber carb/air box and manifolds on TradeMe at the moment for $60ish, if you really get stuck).
Fraser.
PostPosted: Fri Apr 17, 2009 1:45 pm
I found rubber elbows at;
http://store.airflo.com/90hl2.html
I used 2inch (50mm) with the screw on velocity stack on my Dellortos. It all fits tight in the engine compartment, but better than cramming little aircleaners into the rear cylinder. I used a short aluminum sleeve at the end of the hose since the air cleaner had 2" id also, so there are two hose clamps right next to eachother and a third one at the carb. So you need a total of 6 hose clamps.
I'll post a picture this weekend when I get time.
PostPosted: Thu May 07, 2009 9:51 pm
Tim
Port Murray, NJ
1987 Ducati 750 Paso
1995 Ducati 900SS SP
1999 Ducati 996
1998 ST2
2000 Honda RC51
PostPosted: Fri May 08, 2009 6:43 pm
Thanks for the great info Wilbur, as I was already playing around with the old manifold 2 c if it could still face forwards, but ran into problems with the aframe and was still on a lean so float levels r? so thanks never thought 2 run it out the side, so it looks like im buying a new manifold cheers Paul :thumbup:
PostPosted: Sat May 09, 2009 1:03 pm
Nice video and interesting stuff :thumbup: :thumbup: :thumbup: .
PostPosted: Sat May 09, 2009 1:23 pm
Thanks Wibur for very good video and explanation! Great job!!!! absolutely.... :thumbup:
Users browsing this forum: No registered users and 127 guests
