ducatipaso.org • View topic - electrical issue, please help?
It is currently Fri Apr 24, 2026 5:59 pm
 Post subject: electrical issue, please help?
PostPosted: Tue May 05, 2009 7:57 pm
Hi folks:
My 907ie had no front turn signals because the previous owner didnt have them plugged in!
When I did plug them in, the left side worked fine- normal speed, but the right side blinks super-fast (front and rear).
One side normal speed, one side double fast. All the bulbs work.
Any ideas?
Thanks lots.
Sheldon
 Post subject: Re: electrical issue, please help?
PostPosted: Tue May 05, 2009 8:25 pm
Check the bulb wattages in the fast side. If not, it'll likely be the flasher unit.
If that fixes it, please see this thread! viewtopic.php?f=3&t=3257
PostPosted: Wed May 06, 2009 12:45 am
My guess is bad ground/earth on the fast one.
PostPosted: Wed May 06, 2009 1:57 am
I switched the bulbs in the rear and the fast/slow swapped sides. So its the bulb. The rear bulbs are different. Does anyone know what bulb is supposed to be in there?
Sheldon
PostPosted: Wed May 06, 2009 5:32 am
This should be indicated in the lens. 21w/12v
PostPosted: Fri May 08, 2009 5:26 pm
Just like Nicola say, 21W, but IF U change to halogen, or LED blinkers, then You have to change blinker relay also to "clever one", like Kellerman unit, or put resistor to series with bulbs. I just put another pairs of rear blinkers to my ST2 and only way to solve too fast blinking was to buy Kellerman unit! :smoke:
PostPosted: Sat May 09, 2009 12:32 pm
PostPosted: Wed May 13, 2009 4:41 am
i just put LED blinkers on my 750 sport- but only the front - rears are still bulbs. I didn't have any trouble with fast blinking, but one small issue is the LED lights really need a full 12v or they wont turn on - with old ducati wiring the LED blinkers don't work at all with the bike off, hardly show at idle - but are bright and clear at 2000 rpm.
i was thinking of doing the rears to LED as well, but at stops im afraid they would hardly show--
