ducatipaso.org • View topic - 750 paso swing arms
It is currently Wed Mar 04, 2026 11:42 pm
 Post subject: 750 paso swing arms
PostPosted: Sat May 09, 2009 6:13 pm
when i was tightening the chain one of the for bolts on the back of the swig arm striped. any ideas on how to fix the problem???? thanks bender.... :,( :,( :,(
 Post subject: Re: 750 paso swing arms
PostPosted: Sat May 09, 2009 7:42 pm
PostPosted: Sat May 09, 2009 8:23 pm
thanks it is the bottom hole so i will try the "Helicoil" i will let you know how it works. thanks again bender :beer: :beer:
PostPosted: Sat May 09, 2009 10:53 pm
I added 3 helicoil in my swing arm last month and when i was at it, I inserted in front fork for the callipers. They where getting to a state, that I was nervous when tightening them. Alloy and steel bolt’s?? there should be a law stating, that you had to insert an helicoil in to a alloy thread :) :beer:
PostPosted: Tue May 12, 2009 5:41 pm
sounds like it worked good for you hope that it will work good for me to thanks for you're help with this problem. i will let all of you know thanks bender :evil: :evil:
PostPosted: Fri May 15, 2009 8:23 am
