ducatipaso.org • View topic - problem with starting the bike, relay?
It is currently Wed Jun 24, 2026 11:59 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: problem with starting the bike, relay?
PostPosted: Sun May 10, 2009 9:28 am
Clutch kit part # 19020051A i fitted this kit to my 750 , no problems as yet
PostPosted: Mon May 11, 2009 5:40 am
I'm not sure but I think that o-ring is not standard and you'll need an OEM spare part if you find some oil leak
PostPosted: Mon May 11, 2009 5:55 am
you mean clutch fluid leak?
I`ll try to find one today.
and what about bearing? Could it be that I have only pin with bearing balls?
without any other bearing?
and, what I have noticed - the level of pin, and the level of piston are the same,
shouldnt the pin stick out more? (as it take all power from pressure plate)
PostPosted: Mon May 11, 2009 7:59 am
PostPosted: Mon May 11, 2009 3:48 pm
PostPosted: Mon May 11, 2009 6:17 pm
no, i didnt mean spring under the piston :)
at the top of the cover, there are 2 (screw-)threads
one for drain, and another for supplying clutch with clutch fluid
and this one was damaged, previous owner instead of repairng
scre thread, just put there a spring ;)
but anyway..
here are 2more photos:
first - after removing pin, and the second after puting the pin ;)
PostPosted: Wed May 13, 2009 7:56 am
same piston issue in thie thread
viewtopic.php?f=1&t=3278&st=0&sk=t&sd=a
PostPosted: Thu May 14, 2009 5:40 am
Anyway, I can see the outer ring of the bearing (or part of it) still fitted inside the piston.
If you can't pull it out, try to cut it with a dremel grinder, taking a LOT OF CARE not to damage the piston!
Then wash it carefully with nitrous cleaner and grease a bit the seat
PostPosted: Tue Dec 29, 2009 12:57 pm
just going through the parts catalogues I noticed that that piston shown above is the one from the 906.
