ducatipaso.org • View topic - help with wiring electrex reg/rec
It is currently Tue Sep 30, 2025 7:42 am
 Post subject: help with wiring electrex reg/rec
PostPosted: Wed May 13, 2009 8:28 pm
can anybody tell me the exact colour codes to wire this reg/rec to the original wiring because the new one has 5 cables and the old one has 7.
 Post subject: Re: help with wiring electrex reg/rec
PostPosted: Wed May 13, 2009 8:46 pm
http://www.electrosport.com/technical-r ... ctions.pdf
PostPosted: Wed May 13, 2009 9:01 pm
Well, start with what you know.
Here is the document from ElectroSport (Electrex)
Yellow wires are from the alternator, Red and green to the battery, and white to the dash light.
Ground the case just to be safe. solder is better than any connector.
After that, I don't know what wires are attached to the original R/R. Have to get out the wiring shematic at that point.
PostPosted: Fri May 15, 2009 8:40 am
thank you for the information but do you no were the blue and brown wires go from the original wiring ?
PostPosted: Fri May 15, 2009 11:53 am
I don`t have an Electrex regulator but according to the plan it`s:
Electrex to original wiring
yellow -> both pink (alternator)
yellow -> red (alternator)
white -> light blue (charging warning light)
red -> red/black & orange (battery +)
green -> black (battery -)
(the brown wire of the Paso wiring loom formely going to the regulator is not used any longer)
Note: If the measured voltage between the two yellow wires from the alternator (which are pink when they get to the regulator/rectifier) is between 50-100V you should wire the reg/rect as shown on the first picture of the instructions hence connect yellow 1 from the reg/rect to one yellow(pink) wire from the alternator and yellow 2 to the other. In this case the red wire from the alternator isn`t used and can be isolated. Install like this if the first wiring instructions don`t work. (To check simply connect a voltmeter to the battery. When the engine is started and the regulator/rectifier is connected correctly the voltage will increase i.e. from 12V to ca. 14V)
https://app.box.com/s/r16ixjegwfl7aq3ybd0c
from the Paso wiring loom the brown formely going to the regulator is not used any longer.
Someone correct me if I`m wrong.
PostPosted: Fri May 15, 2009 8:29 pm
You're never wrong!
Users browsing this forum: No registered users and 45 guests
