ducatipaso.org • View topic - Greetings and some questions
It is currently Sat Mar 07, 2026 6:38 pm
 Post subject: Greetings and some questions
PostPosted: Tue May 19, 2009 8:35 am
Hi im the proud owner of a heavy modified 750s 1989, and have som issus id like to adress on it. First what are the dimension of the oilcooler lines ( and can i bay those at any leanght ?)
Im a newbie my first DUC. I need a link to filters KN if possible for the weber44. And the last and for me importent issue any manuals an info PDF ?? Im sorry for the english writing, but i hope it can be read :-)
 Post subject: Re: Greetings and some questions
PostPosted: Tue May 19, 2009 10:59 am
Welcome!
Workshop manual here: http://ducatipaso.org/docs/sport/Worksh ... _Sport.zip
Where are you located (please fill in profile)?
PostPosted: Tue May 19, 2009 11:12 am
PostPosted: Tue May 19, 2009 10:57 pm
If you want to not go stock: you can use the fittings from later SS and monster oil coolers if you swap out the nipples at the engine case. the smaller diameter nipples screw right as a direct replacement to the sport- $17 a piece from the dealer, or get some off an old ss engine like i did. I am not sure if you can do the same to the oil cooler itself, as i just used an SS oil cooler as it already had the correct fittings.
I offer this because it gives the option to use stainless steel lines from many of the later model bikes-- and you could probably get some made if none of them are long enough.
PostPosted: Wed May 20, 2009 10:36 pm
hi their i have a k/n filter on my 750 sport. the part number is:k/n 56-1120. hope this helps :thumbup:
