ducatipaso.org • View topic - Spark Plug Wires.... need advice
It is currently Sat Jun 20, 2026 2:28 pm
 Post subject: Spark Plug Wires.... need advice
PostPosted: Mon Jun 08, 2009 1:06 am
Hi!
Just got my 1990 750 Sport running (again).
The wonderful Digiplex 2S gave out and I decided to go for the ignitech TCIP4 unit... very sweet.
New problem has propped up; the plug wire on the vertical cylinder doesn't want to stay on; nuts too... the bike will actually run on 1 cylinder.
Anyway... can the wires be replaced without replacing the coils? I'm hesitant to just go and twist and see if they unscrew.
Thanks!
Carlo
 Post subject: Re: Spark Plug Wires.... need advice
PostPosted: Mon Jun 08, 2009 4:46 am
No, the high tension leads do not simply screw in to the coils. They are bonded in, or overmolded, or something. I can't figure out how they made them, but I do know that the wires can not be replaced. I hate to tell you, but you are now in the market for a new set of coils. Don't feel too bad though, coils do wear out over time, and 20 years is certainly a reasonable time to replace them.
The cheap way is to get a set of stock coils from another Ducati or some other brand off of e-bay. Make sure the resistance matches the new nifty box you got. The second option is to get the hi-perf coils. Dyna coils. get them at Ca. Cycle works http://www.ca-cycleworks.com/
PostPosted: Mon Jun 08, 2009 9:18 am
Looks like I'mgoing to bid on a set of coils to a Monster that I saw on line.
I did however discover that the end caps to the plug wires DO screw off. I'm going to go look for a set of those at the Honda dealership today.
Thanks!
Carlo
PostPosted: Mon Jun 08, 2009 3:36 pm
PostPosted: Mon Jun 08, 2009 3:40 pm
Carlo,
I may have misunderstood your original question, so let me clarify. The high tension lead is not removable from the coil. However, the sparkplug cap can be changed on the wire. As a mater of fact, it will do you well to cut off an inch of wire and screw the plug cap back on to get a fresh connection. The spark plug caps have resistors in them to keep the electronics happy. It is recomended to keep those in the system.
Hope that helps. Cheers,
PostPosted: Tue Jun 09, 2009 9:16 pm
For the price of the coils at cacycles works you can get the coils,bracket and wires from Bevel Heaven in either 3 or 5 ohm both will work on a Paso. Personally I throw as much biz as I can to Bevel Heaven.
