ducatipaso.org • View topic - Mirror Glass
It is currently Mon Sep 29, 2025 7:13 pm
 Post subject: Mirror Glass
PostPosted: Tue Jun 09, 2009 9:24 pm
Anyone found a 100mm convex mirror glass. Closest I have found so far is 95mm
 Post subject: Re: Mirror Glass
PostPosted: Wed Jun 10, 2009 1:17 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Fri Jun 12, 2009 3:42 am
Walmart, 3 bucks,convex 95mm close works good not a perfect fit tho.. same thing at many auto stores. At most auto stores you can get a blank for 4 bucks,not a convex you can cut with scissors to fit. I have had no luck this side of the pond for 100mm. The euro guys don't seem to care :dunno: I did find one convex on a plastic pedestal that rotates,it was 3 bucks and you can rotate it easily on the fly with a gloved hand,but the tape was weak. In the end I might get some good tape and put them on both sides, the rotation allows for fine tuning very quickly. I find it allows for those baggy pant days :lol:
PostPosted: Sat Jun 13, 2009 9:51 am
95mm are 3-3/4", right ?
I didn`t find any 4" (100mm) convex mirrors, but finding 100mm flat ones is no problem. The original ones are also flat.
i.e.
http://www.craftamerica.com/darice_round_mirrors.htm
http://cgi.ebay.com/Lot-of-10-4-Round-G ... 1|294%3A30
in Germany you can find 100mm round flat mirrors in craft supply shops
PostPosted: Sat Jun 13, 2009 10:34 am
95.25 mm is 3.75 inch not that anyone will notice 1/4 mm :mrgreen:
100mm is 3.94 just enough less than 4 inch to fit the plastic mount not that I have found a 4 inch mirror. found 4 and a quarter in convex
Just might have to give them a go,30 mirrors for 13 bucks is quite a deal :thumbup: :thumbup:
PostPosted: Tue Jun 30, 2009 9:21 pm
took a lot of digging but I found a scientific mirror glass supplier that had 100mm convex with a focal length of 250mm,blackened silver backing on glass should be a good quality replacement.
I'll post here when I get them
PostPosted: Sun Jul 12, 2009 5:24 pm
Bought 4 mirrors delivered for 32.17. Not the best silvering job I have seen but they do work and fit well,just a little spotty up close makes them look like they need a good cleaning up close. Took some bon ami cleaner too them and it is definitely the silvering not the surface. Overall I give them a b grade. Good image and perfect focal length.
