ducatipaso.org • View topic - Starting
It is currently Mon Jun 22, 2026 9:19 am
 Post subject: Starting
PostPosted: Sat Sep 04, 2004 1:10 am
My 750 limited has a strang starting problem. the engine won't turn over unless the kill switch is in the off position once it starts to turn over U flick the kill switch to on while itis turning over it will continue to turn over as long as the starter is still prest until start. if it doesn't keep running due to being cold. I have to go thru it all again. :confused:
This isn't a big problem as I can live with it my main question is that is this normal?
Thanks Lionel
 Post subject: Re: Starting
PostPosted: Sat Sep 04, 2004 11:31 pm
PostPosted: Tue Sep 14, 2004 1:45 am
 Post subject: Paso starting problems
PostPosted: Sat Oct 02, 2004 7:47 pm
PostPosted: Fri Oct 08, 2004 1:13 pm
Send me an email and I can forward the info to you.
PostPosted: Fri Oct 08, 2004 7:54 pm
jon send the info to me and we'll make an article out of it for the site.
PostPosted: Mon Oct 25, 2004 8:55 am
PostPosted: Wed Oct 27, 2004 5:13 pm
 Post subject: wiring mods
PostPosted: Thu Jan 13, 2005 7:30 am
:thumbup: I too have recently completed the mods. provided by Jon. The instructions provided were explicit and the mods easily performed. A different bike! I also fitted a fuel pressure regulator in-line with the standard weber carb - smooth tick over and no embarassing cut-outs! Well worth the effort. The total cost was less than £40.
PostPosted: Thu Jan 13, 2005 8:06 am
my bike has been this way for ages too...help..........
PostPosted: Sat Jan 15, 2005 4:11 am
The fix is in your email box.
Good Luck!
PostPosted: Sat Jan 15, 2005 7:07 pm
:thumbup:
hey daza, i installed jon's fix on my bike successfully, even though i have the mind of a 2-year-old when it comes to electrics (the trouble is you can't see the stuff - how am i supposed to understand something i can't see?). anyway, it worked very well. you're welcome to come and look at how i did it on my bike if you like.
