It is currently Mon Nov 02, 2026 3:56 pm
[ 6 posts ] |
| Author |
fredskidoo
Post subject: Anybody using a 150/80/16 rear tire? Posted: Mon Jun 22, 2009 10:03 pm |
Joined: Sat Nov 29, 2008 6:30 pm Posts: 240 Location: Hwy 1 - Tomales, CA - 94971
So I've re-read all I can find here at the "org" about using a 150/80/16 on the rear wheel and there isn't a lot on the subject. I did find this though.
On Mar 25, 2009 - JWilliam states in the "best solution for the Michelin problem" thread.
"The 150/80 is meant for a narrower rim so it spreads out by about 10mm, which is ideal because that makes it a 160"
Anyone have any actual experience using this tire size? If so, how does it fit in regards to width AS WELL AS height. Did you have to space the chain and sprockets. What about height clearance with the 750 swingarm?
Thanks all - Fredskidoo
_________________ '87 750 Paso 751412
| Top |
Post subject: Re: Anybody using a 150/80/16 rear tire? Posted: Tue Jun 23, 2009 5:33 pm |
| paso grand pooh-bah |
to summarize it, just`s just not a size to use. There`s a reason why it`s only recommended for smaller rims. Check every manufacturer`s homepage. Using an inner tube to make it fit on the rim makes even less sense for me personally. Furthermore the tire is so high that most guys who use that size either cut out and modified/rewelded the middle section of the swingarm or cut off the ends and lengthened it. Some feedbacks I read from 750S riders where not very good. Some said the tire behaves odd in curves (depending how low you lean into them). The space to chain and sprocket shouldn`t be an issue. Afterall, you have to decide for yourself. My guess is that the statement that it`s the "best solution" has the background that nothing else was tried. ie 180/60
| Top |
JWilliam
Post subject: Re: Anybody using a 150/80/16 rear tire? Posted: Tue Jun 23, 2009 8:37 pm |
Joined: Wed Oct 06, 2004 12:00 am Posts: 327 Location: Nottingham, UK
You are right that the swingarm must be modded. I would not be happy to fit a 180/60 rear when there is talk of the sprockets having to be out of line (sorry if I don't know too much about this). The 150/80 is a taller tyre than the Michelin but boy does it grip. I can go as low and fast as modern Ducati's and that suits me just fine. If you had a choice then I recommend the 150/80 but in the end it is up to you. I think the 180/60 would be easier and cheaper and the 150/80 longer to get done depending on your local frame builders.
_________________ http://www.youtube.com/watch?v=jf8Ic_aUWug
| Top |
GT-UK
Post subject: Re: Anybody using a 150/80/16 rear tire? Posted: Fri Jun 26, 2009 1:37 pm |
Joined: Fri Jun 26, 2009 12:51 pm Posts: 18 Location: West Yorkshire, UK
I've just acquired a 750 Paso with (you guessed it) a rear tyre close to the limit. I've read various posts about the 180/60-16 tyre but not about a 170/70-16 tyre. This size seems to be available from Dunlop and others and I wondered if anyone had tried fitting one?
GT-UK
| Top |
Post subject: Re: Anybody using a 150/80/16 rear tire? Posted: Sun Jun 28, 2009 8:59 pm |
won`t fit. That size is about as high as a 150/80
| Top |
[ 6 posts ] |
Users browsing this forum: No registered users and 5 guests |
