ducatipaso.org • View topic - Freeplay front sprocket?
It is currently Fri Apr 24, 2026 8:50 pm
 Post subject: Freeplay front sprocket?
PostPosted: Sun May 10, 2009 7:13 pm
Is there any freeplay for the front sprocket to wiggle a little on the shaft?
 Post subject: Re: Freeplay front sprocket?
PostPosted: Mon May 11, 2009 1:31 am
Yes there is. The sprocket is a slip fit and the keeper holds it in place.
PostPosted: Mon May 11, 2009 10:47 am
Thx! :)
PostPosted: Mon May 11, 2009 5:06 pm
Check anyway axle, if there is any wear signs! :smoke:
PostPosted: Mon May 11, 2009 7:39 pm
... and drill the two screws for lock wire while you have them out ...
... and install a "Desmo Times Case Saver Insert" from http://desmotimes.com/
- Kurt
PostPosted: Mon May 11, 2009 11:32 pm
Axle no wear & Desmo Times case saver I have! :thumbup:
PostPosted: Tue Jun 23, 2009 11:49 pm
Speaking of front sprockets, I just ordered a 14T front sprocket from Demo Times. The new sprocket has all the spacing on one side while the stock sprocket has a equal shoulder on both sides. I am worried about chain alignment . What are you guys doing??
