ducatipaso.org • View topic - side panel fairing + boots = scratches
It is currently Tue Oct 27, 2026 6:35 am
 Post subject: side panel fairing + boots = scratches
PostPosted: Fri May 20, 2005 6:45 pm
Is it just clumsy me or did you also accidently left your Paso with scarifications on the side panels after a fast :cool: but satisfying ride?
Last time I had ridden my Pearl White Paso I wore boots with zippers on the outside and inside of my boots. On my Nuda SuperSport that was no problem, but later on, when I was polishing my Paso I discovered deep scratches, grooves so deep there was no paint left... :sad: I must say my clutch didn't work on my way back home, so I had to yank(?) the lever fiercely..., but on the right side it was the same (not a lot of braking :D )... scratches....
Now I am going to use some transparent foil on those weak spots on the panels... I hope that works out.
I also noticed some spots on the tank where my knees are, but to sticker my entire 907ie... not an option I think...
| '92 907 I.E. | '88 750 Paso under construction |
PostPosted: Fri May 20, 2005 9:52 pm
:toofar:
Bad luck, DuC-MaN - you'll have to do something about those boots.
Your bike looks really good in the 'Virtual Meeting' Topic! When is she going to be back on the road?
PostPosted: Sat May 21, 2005 10:05 am
PostPosted: Sun May 22, 2005 7:27 am
PostPosted: Mon May 23, 2005 5:17 am
Redpaso
PostPosted: Mon May 23, 2005 7:07 am
