It is currently Thu Mar 12, 2026 11:00 pm
 Post subject: Need Fuel Petcock? Is it from Paso?
PostPosted: Mon Jun 22, 2009 5:51 pm
I'm missing some parts from my bike and am having a hard time finding gas cap assembly (I think I found an aftermarket that fits) and still need a fuel petcock assembly. Is there two (for the two carbs) or only one lever, can someone please help me out with this info, I'm not sure if one from a Paso might fit.
thanks
Monte Moore
www.maverickcustompaint.com (custom bike paint)
 Post subject: Re: Need Fuel Petcock? Is it from Paso?
PostPosted: Wed Jun 24, 2009 4:14 am
Monte,
I don't know if the Paso petcock is the same or not, but I do know that you don't need one. I removed my petcock years ago with out any negative consequences. The threads in the tank are a standard 10mm x 1.0, which is a standard brake banjo bolt from any Brembo system. (many Japanese brakes have a slightly different pitch) I found a banjo fuel fitting for a 10mm bolt at a store that sold repair parts for a DeLorean. Fits nice and tight. I also added some quick release fittings in line. If you feel you need the shut off, get one of the vacuum operated shutoff from a Monster. they are small and run off of vacuum from your intakes, and they are cheap on E-bay.
PostPosted: Sat Jun 27, 2009 1:46 am
http://search.ebay.com/290326771449
Not sure why there's a keyhole on this one, but the seller says it works without the missing key...
Ben
PostPosted: Sat Jun 27, 2009 4:27 pm
Looks correct. As long as nobody turns that key cylinder, it looks like it will work well.
