ducatipaso.org • View topic - paso fuel pump over runnig carbs
It is currently Sat Mar 07, 2026 12:58 pm
 Post subject: paso fuel pump over runnig carbs
PostPosted: Sun Jul 05, 2009 1:40 pm
Ok, so I have I cleaned the carbs out, replaced fuel lines and started the bike. I had oiled the cylinders down so some smoke but cleared up. The fuel pump however is pushing fuel out of the overflow vents of the 2 dellorto's. I have a return line and double checked float levels and made sure they were seating. The pump never seams to shut off. Also, the previous owner had carb jets in the fuel line leading to each carb. So maybe he had this problem and thought he was going to fix it. Any suggestions?
 Post subject: Re: paso fuel pump over runnig carbs
PostPosted: Sun Jul 05, 2009 10:12 pm
yes, bypass the pump: dells don't need it!
PostPosted: Mon Jul 06, 2009 1:29 am
Really??? No pump for dellorto's? I thought the pump was there because the outlet from the tank is lower that the carbs. Here's the deal for today. Re checked float levels and tried my "test" gas tank that hangs like an IV bottle and they don't leak. Then tried it with the pump and they don't leak. I found out the jets in the fuel line were for the emission system from the canister to the carb, the previous owner used it as thefuel lines. Now I just need to adjust the carbs so it will idle properly.
And yes I am still thinking about making it naked. :shock:
PostPosted: Mon Jul 06, 2009 10:15 pm
PostPosted: Mon Jul 06, 2009 10:16 pm
PostPosted: Tue Jul 07, 2009 1:06 am
Had a Monster. No money in the budget for a new bike. So the freebee Paso fits the bill. :thumbup:
PostPosted: Tue Jul 07, 2009 11:07 am
PostPosted: Sat Jul 11, 2009 1:47 am
Thanks again for the help. I also got a 4 x 8 sheet of aluminum to start cutting up to see what I can come up with as a naked aluminum tanked and faired paso. I'll probably need a new leather bag and malletbu the time i'm done.
PostPosted: Sat Jul 11, 2009 9:26 am
If you have decided on make naked your Paso, PLEASE do it so that she can come back a Paso...
Ciao :thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
PostPosted: Sat Jul 11, 2009 10:40 pm
I have a similar problem was wondering if you also disconect the return line as well since the carbs wont be under preasure?
PostPosted: Mon Jul 13, 2009 11:49 am
You can remove it if you wish. The Dell's work great with just a gravity feed.
PostPosted: Mon Jul 13, 2009 2:07 pm
How about the Mikuni's?
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
PostPosted: Mon Jul 13, 2009 3:09 pm
if you have Mikunis keep the fuel pump and the return line also. (an extra pressure regulator is also not needed)
PostPosted: Mon Jul 27, 2009 8:14 am
When i had 40 mm Dellortos in my 750 Paso, i didnt use fuel pump and it function well... Ok, maybe "little too thirsty"... :smoke:
Users browsing this forum: No registered users and 30 guests
