ducatipaso.org • View topic - Sourcing Nipples to attach Vacuum balancer?
It is currently Fri Mar 06, 2026 4:37 am
 Post subject: Sourcing Nipples to attach Vacuum balancer?
PostPosted: Fri Jul 17, 2009 10:51 pm
Jon Suggested that Mig Welding tips would screw into the intake manifolds. Does anyone have any additional suggestions as to where one may source nipples to attach a homemade vaccuum balancer to the intake manifold?
RADDUCK
02 Honda RC51 SP2
87 Paso 750 - Dropped but ride-able
03 Triumph Bonneville - Basket case (resto in the works)
88 Porsche 911 Carrera
04 Subaru STI
 Post subject: Re: Sourcing Nipples to attach Vacuum balancer?
PostPosted: Fri Jul 17, 2009 11:48 pm
OK, did some research. The thead is supposed to be M5 x .8.
You can pick up some M5 x .8 allen bolts and drill a hole down thru the center to make some nipples. Put some grease on the outside to make a seal so you get good vacuum.
PostPosted: Sat Jul 18, 2009 12:06 am
EUREKA!!!!
http://www.motionpro.com/motorcycle/partno/08-0013/
or
http://www.z1enterprises.com/detail.aspx?ID=3263
Or
http://www.aerostich.com/product.php?productid=19775
PostPosted: Sat Jul 18, 2009 5:36 pm
Wow Jon! That's 5 options in less than 24 hours. If only I could get that level of service from the dealer. I'd say you've gone above and beyond the call of duty. I was going to swing by a welding shop today and check out the mig tips but It was easier just to click and pay. Thanks again! Your help is much appreciated!
RADDUCK
02 Honda RC51 SP2
04 Subaru STI
