ducatipaso.org • View topic - Paso 750 Rear Tire solution (160/60/16)
It is currently Thu Jun 18, 2026 12:37 am
Post new topic Reply to topic  [ 270 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 18  Next
 Post subject: Re: Paso 750 Rear Tire solution (160/60/16)
PostPosted: Wed Jul 22, 2009 6:07 pm
In front I moved the fender 6mm up (alu spacers) -> Metzeler SPORTEC M3 FRONT 130/70 ZR16.
To move the Crown to the left I made an alu Plate. I made documentation with Fotos and all plans for the change. But I’m still working in it. The avon is nice to drive (excellent grip, good handling in combination with the Metzeler) but making headache because of the size. Moreover I have troubles with the right wheel bearing.
As soon I have everything sorted out I’ll put the whole documentation incl. pics on the forum. The plans for the alu plate I can send you by mail if you need ( I have some problems to put pics on the Forum)
I have actually a plate of 8.5mm. But I made just two others of 9.5 and 10.5 mm (as already mentioned, de Avon is big). Moreover I moved the sprocket 4.5mm to the left (plans for this parts are as well available).
For the time being I would recommend you the Shiko, which seems to be smaller than the Avon.
pasoalf
Paso 750/ 1987
Paso 906/ 1992
PostPosted: Thu Jul 23, 2009 7:57 am
Just an FYI guys...... The 747 Shinko is not shown on the Shinko USA website anymore, dunno but Motorcycle Superstore showed it as a closeout item when I ordered so it may be now another discontinued option...... I ordered 2 just in case.
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
PostPosted: Fri Jul 24, 2009 2:53 am
I have to move up the front fender using alu spacers too :thumbup:
70 hp. can change the world
PostPosted: Sun Aug 23, 2009 12:37 pm
As I was writing already 2 or 3 years ago that my next set would be Avons I finally got mine, too.
Paid €98 for the front AV45, €130 for the rear AV72 (mounting was €34 - grrr). (german webshop: http://www.mynetmoto.com ) Listprice of the rear tire is €219 according to the tire shop where I got them mounted on the rims. They sell it for €148,- which proves that there are huge price differences with Avon tires and that checking numerous shops really pays off.
Production date of my new set is cw19 and cw21/2009.
Front and rear tire are quite a bit different compared to the old ones. The front tire is a bit higher and rounder shaped, the rear is quite a bit taller and wider than the old one. All in all that should affect handling positively.
I put them on the bike this morning so here`re some pics. Clearance of the rear tire is about 10mm to side and front with the excentric adjuster in middle position.
I didn`t do anything with the chain yet, as I have to finish some other things first, but I`ll post my solution when it`s done.
The main general issue I see is that the stands are too short. The center stand only touches the floor with one leg so I will put on one of a 907ie this afternoon. The side stand is also too short and as a consequence the bike leans over too much. Update: the 907ie centerstand works just fine as it is a little longer. The bike stands with both wheels touching the ground, but it stands stable.
PostPosted: Sun Aug 23, 2009 5:39 pm
Have you ride it???
Sensations???
PostPosted: Sun Aug 23, 2009 5:47 pm
Great fotos and good details!
I have been also thinking "only" this combination to my 750 Paso. Let us know, how much chain hits to side of rear tire, or do it so at all... Are you planning to change chain line offset?
PostPosted: Sun Aug 23, 2009 6:29 pm
Why didn't you use the 120/70/16 pirelli diablo at the front?
I need new tires for mine as well and i was thinking the diablo in the front and a 180/60 dunlop at the rear
PostPosted: Sun Aug 23, 2009 6:37 pm
PostPosted: Mon Aug 24, 2009 11:27 pm
PostPosted: Tue Aug 25, 2009 3:57 pm
PostPosted: Fri Aug 28, 2009 11:50 am
Hallo to everybody ,i'm new of this forum . Iwrite from Enna , Sicily , and my english is beatifull :,(
If i can , i have question . I read in this forum that someone put the tire in his paso without problem and modification . but i don't found the post now . The tires were : front dunlop 208 rr 130/70 16 and rear shinko 180/60 16 ?
I have adjust my paso 750 , but my tires have 9 years , and seems to be always in rain street :banghead:
Thank you and a sunny hallo to everibody
PostPosted: Fri Aug 28, 2009 12:49 pm
Hello and welcome. Just check the SEARCH function and you`ll see that the thread you`re looking for is this one. Just go back to its first page.
PostPosted: Fri Aug 28, 2009 4:12 pm
PostPosted: Fri Aug 28, 2009 4:44 pm
Thankyou to everyone, i'm happy to have found a place where to have information about my moto , i love she and i want ride it for long time .
PostPosted: Fri Aug 28, 2009 5:21 pm
This is the best place where we can share infos about our motorbikes.
Besides, here you will always get answers to your problems.
Finally, don't exitate to write in Italian.
I hope to see you again.
