ducatipaso.org • View topic - Mikuni float height????
It is currently Sun Mar 08, 2026 11:11 am
 Post subject: Mikuni float height????
PostPosted: Wed Jul 29, 2009 9:08 am
I searched and could not find anything for the Mikuni's I have..... Mine have the floats in the bowl on rods which push up the tabs connected to the needle valve. I need to know at what height I should set the tabs, right now it pushes gas out the vent tubes so I know the short answer is they should be lower :wacko:
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
 Post subject: Re: Mikuni float height????
PostPosted: Wed Jul 29, 2009 10:13 am
try
PostPosted: Wed Jul 29, 2009 10:15 am
try
also
so basically there are 2 choices depending on which flat slide you have.20mm for the early version and 18mm for the rest
PostPosted: Thu Jul 30, 2009 2:11 am
I think you'll find that Mikuni BDST38 CV carbs from Monster/SS have a float height of 14mm from the gasket base to the diamond shaped float with the carb tilted enough to get the float tab to touch but not compress the fuel shutoff valve.
this is a useful trick - bottom of page "Float height setting trick"
http://www.factorypro.com/Prod_Pages/prodd09.html
Tony
PostPosted: Thu Jul 30, 2009 9:07 am
Found it on the Mikuni site.... I have VM's, looks to be .66 to .74 inches. I'll be giving it a try today and see what I come up with... Thanks guys.
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
PostPosted: Thu Jul 30, 2009 10:00 am
so that is 16 to 18mm for your that speak metrically
