ducatipaso.org • View topic - Back in the game
It is currently Mon Mar 09, 2026 5:55 pm
 Post subject: Back in the game
PostPosted: Mon Jul 27, 2009 2:37 pm
1988 Paso 750 #753965
1997 Monster 750
 Post subject: Re: Back in the game
PostPosted: Tue Jul 28, 2009 9:56 am
Hey Faster welcome back.
Once the suspension and bits/peices are complete the Mikuni carb swap and electrical upgrade are absolutely essential.
The Mikuni change makes a remarkable difference (use foam pod filters and remove the air box as well) the smoothness and power makes it a different bike.
Same with the electrical upgrade, easy starts from now on. First time I cranked the bike over after doing the electrical upgrade was a little dissapointed as it still turned over a bit slowly. Had left it in 1st gear and it nearly started. In neutral it spun over with vigor and provides easy starting.
For the oil crank case breather I just disconnected the last hose from the wee breather box near the battery and installed a small mesh filter which just screwed into the spigot the the hose fitted onto. The mesh filter was from a plumbing store, does the job.
Fraser.
750 Paso
1980 Moto Morini 500 Sport
2013 Yamaha MT-01
PostPosted: Thu Jul 30, 2009 10:51 am
You are always lucky if you can tell about an accident riding the bike :shock: :shock: :shock: :shock: :shock: .
Happy to see you back.
Ciao :thumbup: :thumbup: :thumbup: :thumbup:
PostPosted: Fri Jul 31, 2009 3:17 am
Thanks Francesco :) I was lucky, indeed. The phone call to mrs.fasterdammit wasn't one I ever wanted to make ... but at least I could start it off with "first, I'm ok ... " ;)
About the Monster ... they totaled her, but I bought her back (100USD!) so I decided to skip making her a track bike, and rebuild instead. I don't care that she'll be a 'salvage' - she'll still be on the road. :)
And it got me to start fixing Il Vecchio Blu ... :)
1997 Monster 750
PostPosted: Fri Jul 31, 2009 6:39 am
PostPosted: Sat Aug 08, 2009 12:53 am
For the crankcase breather, retain the hose which exits from behind the vertical cylinder and install a K&N dry pleated filter in it; should fit right in front of the battery box. I don't have the part number at my fingertips but can get it if you need. Remove the other stuff. I've also found that although the twin oil coolers are somewhat of a pain when removing the bodywork, they really do a very good job at keeping the oil cool. Hope this helps.
PostPosted: Wed Aug 12, 2009 3:47 pm
1997 Monster 750
PostPosted: Sun Aug 16, 2009 2:30 pm
I'm having new oil lines made up now. They can be made at any local auto parts store for 50 bucks. No need for hight $$ stainless lines that are always hidden :-0
