ducatipaso.org • View topic - Dellorto throttle cable help
It is currently Mon Jun 15, 2026 4:20 pm
 Post subject: Dellorto throttle cable help
PostPosted: Fri May 27, 2005 4:10 am
Hey all. I took the Paso out yesterday for about a 75 mile run through the canyons. I forgot how much fun that bike is when it's running soooo good. However, I have the Dellortos and I also forgot how "heavy" the throttle is. After about 35 miles my wrist was starting to hurt and my hand got tired. I have lubed all the cables and the cable run at the throttle housing but it's still really heavy. Any ideas on how to lighten that up? Can you get lighter springs for the Dellortos? Maybe an aftermarket throttle that uses a different pulley system? Any ideas would be much appreciative.
1988 Red Ducati Paso 750
1999 BMW R1100S
PostPosted: Fri May 27, 2005 12:46 pm
Step 1: http://tinyurl.com/9lhbu
Step 2: Cut the spring down by 1". Spring engineering is very complicated and (trust me on this) cutting the spring shorter actually makes it more firm/stronger. The trade off is that the slightly shorter length provides less preload which is more of a benefit.
Did I mention the throttle rocker? ;-)
PostPosted: Fri May 27, 2005 1:35 pm
Thanks for the suggestion. I was thinking the same but I wasn't sure. I already have the "throttle rocker" and it keeps coming loose or slipping. I already had plans to try and re-engineer it. If I cut the spring does it make it any lighter or does it just change the progression of the throttle on?
1999 BMW R1100S
PostPosted: Fri May 27, 2005 8:33 pm
:cool:
Hey Jon, you have a Malossi throttle on your bike, eh? My bike came with a Malossi fitted, so I don't know how it compares to the standard Paso throttle, and I therefor have not recommended it to ahdoman, but what do you think?
Also, ahdoman, you could make the throttle easier to turn by wrapping some heavy foam rubber sheet, with double-sided tape, around it, thereby increasing it's diameter. My Malossi grip is much bigger and softer than other grips I've come across, and I like it.
PostPosted: Sat May 28, 2005 2:05 am
PostPosted: Fri Jun 03, 2005 2:06 pm
1999 BMW R1100S
Users browsing this forum: No registered users and 45 guests
