ducatipaso.org • View topic - Conical spacer outer diameter in 907IE rear axle???
It is currently Sat Apr 25, 2026 10:51 pm
 Post subject: Conical spacer outer diameter in 907IE rear axle???
PostPosted: Mon Sep 07, 2009 4:04 pm
If someone knows outer diameter of that spacer, it would be nice to send it to Gerhard, as he needs to know measurement. My both spacers are in my bikes, so its impossible to measure them, as there is no space enough for meeasuring tool.... Easy to measure, when rear wheel is out.... :smoke:
 Post subject: Re: Conical spacer outer diameter in 907IE rear axle???
PostPosted: Mon Sep 07, 2009 5:18 pm
thanks Antti. I`ll make it 5cm that should be fine. The swingarm is 8cm high.
PostPosted: Mon Sep 07, 2009 8:23 pm
I am having to measure with a rule at the mo' as I can't get to my tools but the outside width is 46mm, inner hole width is 25mm, outer edge is 3mm and inner edge is between 5mm and 6 mm
PostPosted: Tue Sep 08, 2009 5:14 pm
...just right part! :thumbup:
PostPosted: Tue Sep 08, 2009 7:05 pm
thanks a lot !!!
Users browsing this forum: No registered users and 27 guests
