It is currently Sun Nov 01, 2026 2:52 pm
 Post subject: Throttle cable
PostPosted: Wed Sep 16, 2009 10:06 am
Does anyone know where I could get a standard throttle cable for a 750 Paso? Venhill say they could make one but they need me to send one to copy.
Thanks.
 Post subject: Re: Throttle cable
PostPosted: Wed Sep 16, 2009 4:01 pm
have you checked your local Duc dealer ?
If you can`t find anything there`s also one on ebay
http://cgi.ebay.com/ebaymotors/Ducati-C ... 3aUSQ3a101
PostPosted: Thu Sep 17, 2009 3:47 pm
Thanks for that info. All the local Ducati dealers don't have one and it is listed as obsolete in the Ducati parts system. Unfortunately I missed the end of the eBay item. Does anyone know if a 904 Paso throttle cable is the same or similar to the 750 Paso?
Thanks.
PostPosted: Thu Sep 17, 2009 3:50 pm
Oops. I meant the 906, not 904.
PostPosted: Thu Sep 17, 2009 3:56 pm
I`m sure it`s the same, the 906 has same carbs, same throttle grips etc, although it does have a specific 906 part number but that doesn`t mean much.
If the part on ebay wasn`t sold you can still contact the seller. Usually no problem.
Or maybe http://www.mdinaitalia.co.uk/paso.html
Actually I might even have one, need to look.
PostPosted: Fri Sep 18, 2009 1:39 pm
I do have one.
