ducatipaso.org • View topic - Valve Adjustment
It is currently Wed Jun 17, 2026 10:19 am
 Post subject: Valve Adjustment
PostPosted: Wed Sep 15, 2004 5:10 pm
PostPosted: Sat Sep 18, 2004 4:24 pm
Here an interesting article with photos...
LC
 Post subject: Valve Adjustment - ducatitech.com
PostPosted: Mon Oct 11, 2004 3:47 pm
Thank you for the reply, but the ducatitech article is for a newer 2 valve motor, which has a rocker arm that can be moved for access to the valve shims, and is retained by a clip. The Paso motor has a rocker arm that requires the rocker-arm shaft to be removed to gain access to the valve shims.
All of the technical articles that I could find are for the newer motor. Maybe I can exchange the cylinder heads for those from a newer motor!
 Post subject: Re: Valve Adjustment - ducatitech.com
PostPosted: Mon Oct 11, 2004 3:59 pm
PostPosted: Mon Oct 18, 2004 4:51 pm
PostPosted: Thu Nov 18, 2004 7:46 pm
Have you solved your problem yet, jfiore?
You shouldn't need any special tools. I don't have the rocker clip in my bike either, and I did the valves just after I got my bike. I used a screw to pull the shaft out, and it went back in quite easily.
It's important to do the job with the motor dead cold - like after sitting overnight - any warmth in the motor will give you false readings for the clearances.
