ducatipaso.org • View topic - 906 IGNITION SWITCH
It is currently Mon Sep 29, 2025 11:02 pm
 Post subject: 906 IGNITION SWITCH
PostPosted: Sat Oct 24, 2009 11:37 pm
So here is the damage I did to my switch,lucky for me I have a spare so don't need to repair :thumbup: :thumbup: just swap out the bad parts
a little careful trimming off the melted plastic should work if you are not so lucky
 Post subject: Re: 906 IGNITION SWITCH
PostPosted: Sun Oct 25, 2009 10:21 am
Just typical for Paso keylock.... too much current and bad connections => adding "main relay" helps to thiskind problems... :smoke:
PostPosted: Sun Oct 25, 2009 12:46 pm
Yup,have the relays( 5 nice bosch jobbies) just been doing other things. Converting to dual H4's didn't help either. Have a zenon kit sitting around that I have as yet not gotten too.
Lot of things to do :thumbup:
PostPosted: Sun Oct 25, 2009 1:52 pm
Especially with 2 headlights it's wise to add extra relays. I would say, that one for low beam, one for high beam and one main relay... plus surely one for coils in 750 Paso... :smoke:
PostPosted: Sun Oct 25, 2009 2:43 pm
That's the plan,just got to do it :thumbup:
Users browsing this forum: No registered users and 36 guests
