| It is currently Wed Mar 04, 2026 5:58 pm |
[ 9 posts ] |
| Author | Message | |||||
| englishstiv |
Joined: Wed Apr 09, 2008 9:57 pm Posts: 1097 Location: Manchester, England. model: 907 I.E. year: 1992 |
| Top | ||||||
| higgy |
Joined: Tue Jul 29, 2008 9:50 pm Posts: 3259 Location: Hilltown,Pennsylvania model: 906 Paso year: 1990 |
| Top | ||||||
| ducinthebay |
Joined: Sat Sep 03, 2005 12:00 am Posts: 1323 Location: SF Bay Area model: 750 Sport year: 1990 |
| Top | ||||||
| higgy |
| Top | ||||||
| paso750 |
Joined: Sun Jul 18, 2004 12:00 am Posts: 5494 Location: southern Germany model: 750 Paso year: 1987 |
| Top | ||||||
| englishstiv |
| Top | ||||||
| jcslocum |
Joined: Mon Jul 19, 2004 12:00 am Posts: 1714 Location: Eastern Shore, MD model: 750 Paso year: 1988 |
| Top | ||||||
| paso750 |
| Top | ||||||
| Finnpaso |
Joined: Mon Jul 26, 2004 12:00 am Posts: 3081 Location: Finland |
| Top | ||||||
[ 9 posts ] |
Users browsing this forum: Google [Bot] and 14 guests |
| You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum |
Seems that the simplest solution would be just to have flanges made to weld onto the wheels. All that is needed is a T6 plate to cold roll into the proper shape if my info is accurate. At this point I am not even sure that the original flanges need to be removed. If this in fact turns out to be the case then there would be no need to find a lathe with a more than 10 inch swing something that would significantly lower the cost of converting to 17. Truing of the finished weld up can be done on an axle stand with a grinder and a jig and possibly a hydralic jack a very simple setup. Even if the original flanges need to be reduced this also could be done on an axle stand with grinder jig.
