ducatipaso.org • View topic - Need good photos of carb linkage!
It is currently Tue Mar 10, 2026 4:21 pm
 Post subject: Need good photos of carb linkage!
PostPosted: Wed Nov 11, 2009 3:18 pm
Since I cannot locate a used carb linkage for my Weber, I'm forced to fabricate one if I want to ride my Paso. I need some good close up pics of the linkage extending from the carburator to the throttle cable end. All I have is the cable--and nothing else!
I see the 'ball' connector at the carburetor bellcrank, but there is no 'connection' between the carb and the cable.
HELP!!
Rick
Rick
2004 BMW K1200RS
2004 Royal Enfield Bullet 500
1988 Ducati Paso 750
1981 Honda CBX 1050
 Post subject: Re: Need good photos of carb linkage!
PostPosted: Wed Nov 11, 2009 3:29 pm
Rick,
I can make some pics by tomorrow.
PostPosted: Wed Nov 11, 2009 11:09 pm
Must not have looked very hard :lol: whiner,someone call a whambulance :cool:
Just kidding Look here
and bring cash lots of it :choo:
What do you have to trade? I have all you need :mrgreen: :mrgreen: :mrgreen: :choo:
PostPosted: Thu Nov 12, 2009 1:41 am
Nice link, but it doesn't solve my problem; I still don't know what is missing. If you have what I need let me know a price...
Rick
2004 BMW K1200RS
1981 Honda CBX 1050
PostPosted: Thu Nov 12, 2009 4:48 am
Hope these will help?
This is the end that the cable comes in
if you need some measurements let me know
Rgds Jay.
PostPosted: Thu Nov 12, 2009 10:53 am
PostPosted: Thu Nov 12, 2009 11:02 am
You need both ends of the cable? or just whats on the carb? Choke stuff too?
PostPosted: Thu Nov 12, 2009 12:08 pm
2mm material thickness, edges rolled for better stability.
@jayh
what is that thing infront of your carb, a fuel pressure regulator ?
PostPosted: Thu Nov 12, 2009 2:57 pm
Excellent shots, fellas'! I see that the adjustable rod, spring and black rubber thing are all that I'm missing. If anyone's got them lying around, I will gladly pay...
Rick
Thanx!!!
Rick
2004 BMW K1200RS
1981 Honda CBX 1050
PostPosted: Thu Nov 12, 2009 5:16 pm
so you`re just missing the accelerator cable ? That`s all one piece. (I think)
I thought you`re missing the bracket that holds it.
PostPosted: Thu Nov 12, 2009 6:19 pm
ell, if you look at the last photo posted by paso750, you will see everything I am missing. My throttle cable is attached to the throttle tube/housing and it moves, but the carb end of the cable just has a metal 'knob', like most throttle cables.
Does the original cable bring the spring, plastic thing and adjusting rod all attached to it?!
I don't think so, but I might be wrong; I think the assembly in the photo that I'm missing is separate from the cable...
Rick
Rick
2004 BMW K1200RS
1981 Honda CBX 1050
PostPosted: Thu Nov 12, 2009 7:00 pm
Thats right Paso750 its the holley 12-804 fuel reg mounted upside down,fits in there
just nicely with easy access to mounting screws and a hex key can easily be used from between forks to adjust :thumbup:
Jay.
PostPosted: Fri Nov 13, 2009 12:28 am
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Fri Nov 13, 2009 2:28 am
So all you need is the cable ?
PostPosted: Fri Nov 13, 2009 2:53 am
Okay, here's the deal: the ONLY thing I am missing from my Paso's throttle cable linkage are the parts in the last photograph provided in the post by paso750. It's the ball socket-threaded rod-coil spring-plastic spacer looking thing. Nothing else. ;)
If this assembly is part of the throttle cable assembly, then, yes, I do need a new throttle cable assembly.
I hope I didn't confuse anyone...
Rick
Rick
2004 BMW K1200RS
1981 Honda CBX 1050
