ducatipaso.org • View topic - Airtech 8 piece Paso fairing set F/S or Trade 4 clutch
It is currently Wed Apr 29, 2026 9:30 pm
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: Airtech 8 piece Paso fairing set
PostPosted: Mon Jul 27, 2009 8:45 pm
USPS is the cheapest way to ship internationally and without all the BS custom charges fedex or ups will incur. It can all be done online and even schedule the pickup.
Airtech is first rate bodywork and takes paint very well. It is a lot of work to fit them but well worth the effort and much lighter than the stock body work. The only issue I have had with mine is a small split in the upper ear on the right size after having my tank welded,seems there was a block in the return line and when we added the argon the pressure hit about 9psi and expanded the tank across the top making the fit of the fairing tighter. I just glued it back with some testor's glue and will put my spare tank on after I change the color to match.
PostPosted: Fri Oct 30, 2009 1:09 am
UPDATE!!! This fairing set IS still available . . . as of October 29th, 2009
Fredskidoo
'87 750 Paso 751412
PostPosted: Fri Oct 30, 2009 4:52 am
I'm interested in the windscreen fairing only, if you are willing to part it out.
Phil in Fremont
phildotstobatgmaildotcom ;)
PostPosted: Fri Oct 30, 2009 8:39 am
Sorry mates - all or not
Thxs
'87 750 Paso 751412
 Post subject: Re: Airtech 8 piece Paso fairing set F/S or Trade 4 clutch
PostPosted: Sat Nov 14, 2009 5:43 pm
Hey Phil
If you haven't already checked out Airtech here is the link to the Paso fairings page.
http://www.airtech-streamlining.com/duc ... 986-87.htm
The piece your looking for is $160. The quality is great. People say that Airtech stuff is thinner and not as good as Ducs original bodywork BUT lighter IS better and its strong, more flexible (much less likely to crack) and the price is about $500 cheaper than the dealer and even cheaper than someone selling a used one. As far as using something used versus new you'll end up with a very clean surface to paint, no cracks, no fiberglass strengthening and repairing AND since you'll have to cut out the hole for the headlamp you have endless options as far as modding your headlamp without having to, once again, do any fiberglass and/or bondo work.
Easy, Ethan
'87 750 Paso 751412
PostPosted: Sun Nov 15, 2009 9:08 pm
You still willing to trade for a clutch?
PostPosted: Mon Mar 01, 2010 5:34 pm
Did you source a clutch yet? I have a set of plates with just over 8k on them (easy street use) that I was keeping for a spare. You can have them for $40 plus shipping.
Figured I'd put it out there if you were in a bind.
Thanks,
Gunther
Gunther.Sprecher@gmail.com
760-914-1981
RADDUCK
02 Honda RC51 SP2
87 Paso 750 - Dropped but ride-able
03 Triumph Bonneville - Basket case (resto in the works)
88 Porsche 911 Carrera
04 Subaru STI
PostPosted: Sun May 08, 2011 3:39 pm
If not found yet;
http://cgi.ebay.de/Kupplungslamellen-St ... 2308556f1e
PostPosted: Wed Jan 09, 2013 1:25 pm
Hello, I am interested in the body work for the Paso if we can agree on a price. I live in The Netherlands but I visit my family in the US 3 times per year so it can be sent to their address and I will take it from there. Greetings, F. Dyhl
PostPosted: Sun Feb 03, 2013 8:34 pm
'87 750 Paso 751412
