ducatipaso.org • View topic - PRELOAD-Air in forks
It is currently Sat May 02, 2026 3:59 pm
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: PRELOAD-Air in forks
PostPosted: Sat Mar 07, 2009 6:24 pm
PostPosted: Sat Mar 07, 2009 6:28 pm
PostPosted: Tue Mar 10, 2009 5:48 am
they are certainly air release...
I had a set on an XS1100 years ago..and tried pressurizing them (BAD idea).
first...you can't balance the pressure in each fork...so what does Laddie do??? connects both forks to ONE valve with a tee fitting and plastic tube (just brilliant...methinks)..
result: seems like riding on a cushion of air..for a while...but there is increased stiction to get them to move at first...
all is good until eventually oil pisses EVERYWHERE because the seals will wear VERY quickly...the air pressure forces the seal lip in contact with the fork, by this time the air is lost instantly.
PostPosted: Tue Mar 10, 2009 1:36 pm
PostPosted: Wed Mar 11, 2009 10:59 am
The Goldwing had this set up and it was supposed to have 7 PSI in the front minimum.
It's been sold tho and I only got to ride it for about 50 miles.
PostPosted: Wed Jun 10, 2009 4:54 pm
Hello!
As a new member, it's a pleasure to learn that it's dangerous to measure air presure in M1R fork, especially because there is NO air in it ! I do like this kind of humour, guys, and it's very usefull to improve my english !
PostPosted: Mon Nov 16, 2009 10:08 am
Hey 227708 (Robert from Brizbi, AZ)
I tried that link concerning Marcozzi forks:http://www.moto-one.com.au/performance/851workinpro5.html and its dead. Any chance you downloaded/copied the webpage?
Ethan
'87 750 Paso 751412
PostPosted: Mon Nov 16, 2009 10:25 am
Ethan,
try waybackmachine http://www.archive.org/web/web.php
http://web.archive.org/web/*/http://www ... npro5.html
PostPosted: Mon Nov 16, 2009 11:17 am
Nice one G :thumbup:
'87 750 Paso 751412
PostPosted: Mon Nov 16, 2009 7:43 pm
All old motoone reports here:
http://www.bikeboy.org/performance.html
