It is currently Fri Apr 24, 2026 8:02 pm
 Post subject: 748/916/996/998 Ft wheel, does the front fit a 907?
PostPosted: Wed Nov 18, 2009 3:39 am
I know that 851/900 17' rims fit, but do the later models, 748/916/996/998 fit a well?
This is only for the front rim of course
ta
Nigel
91 907IE - full restoration
MPL Slipper,Ceramic exhaust
Lambretta LI150 S3
87 928S4
 Post subject: Re: 748/916/996/998 Ft wheel, does the front fit a 907?
PostPosted: Wed Nov 18, 2009 5:46 am
Everything will fit, except the 20 or 25mm ID bearings. You'll need to make a new spacer between the bearings if you swap them out.
