ducatipaso.org • View topic - 16 in rear wheel solution?
It is currently Fri Mar 06, 2026 1:35 am
 Post subject: 16 in rear wheel solution?
PostPosted: Sun Nov 15, 2009 12:51 am
Hi
As everybody knows there`s a problem to find a desent rear tyre for our beloved 750 Sport and Paso. I have beeen thinking, is it possible to make the egde of the rim taller by welding and machining, and a 17 in tyre could be used?
Does someone know if it can be done?
I think the Oscam rim is much better looking than the newer 3 spoked SS rim is. It disturbes the design of the bike if you convert to 17 in SS rims like many do. That`s my opinion.
Also, does somebody knows if a 16,5 in tyre could be used?
Regards
Ottovalvole
 Post subject: Re: 16 in rear wheel solution?
PostPosted: Sun Nov 15, 2009 9:01 am
look in the forum and use the search function and you will find it all.
viewtopic.php?f=1&t=3678
PostPosted: Sun Nov 15, 2009 9:43 am
PostPosted: Fri Nov 20, 2009 10:43 pm
