It is currently Fri Apr 24, 2026 2:57 pm
 Post subject: adjusting clutch biting point ??
PostPosted: Sat Nov 21, 2009 12:50 pm
Hi all, My 907 had a recent new clutch fitted before i bought it but the biting point is very close to the bars, this makes it tricky when changing down the gears as you slow down.
How can i adjust this ?
 Post subject: Re: adjusting clutch biting point ??
PostPosted: Sat Nov 21, 2009 1:19 pm
It's not designed to be adjustable, but you can try
a) bleeding the clutch line
b) if that doesn't help, remove the clutch pressure plate and put a small ball bearing inside the pressure plate bearing cup, ie so it lengthens the pushrod.
One or both of the above will work no probs.
Failing that you could fit a bigger bore master cylinder (eg from a later bike). Will also fix the problem.
PostPosted: Sat Nov 21, 2009 5:57 pm
there should be a little screw in the lever (Allen 3) or you can buy a more modern lever, which has an excenter to adjust the biting point.
Ducbertus
PostPosted: Sat Nov 21, 2009 6:06 pm
Thanks guys, I had adjusted the screw in the lever but it wasnt much better. I bled the clutch and its much better now, The fluid was black and i got quite a bit of air out of it.
I was going to go out on it to see if its a lot better but its P!55*ng it down now :,(
Maybe tomorrow :)
PostPosted: Sat Nov 21, 2009 6:41 pm
Remember to do a very accurate bleeding work.
If not, you'll have many problem to find the neutral during the ride.
Ciao :thumbup: :thumbup: :thumbup:
