ducatipaso.org • View topic - flywheel for Kokusan ignition system
It is currently Sun Sep 28, 2025 5:41 pm
 Post subject: flywheel for Kokusan ignition system
PostPosted: Mon Nov 09, 2009 2:51 am
Hello,
I made the change to the Kokusan ignition systemm I am looking for the newer two pickup flywheel. Does anyone know which flywheels are compatible with a 1990 750 sport. There is a 900 ss flywheel currently on ebay. Just wondering about compatibility?
Joe
1990 Ducati 750 Sport (mine)
2008 Piaggio MP3 500 (wife's)
My Ducati Blog site
Stupidity is not a crime, your are free to go ;-)
 Post subject: Re: flywheel for Kokusan ignition system
PostPosted: Thu Nov 12, 2009 6:28 am
900ss flywheel will work.
You may have to swap the flywheel holder if it is an early Paso with a coarse spline flywheel hub.
PostPosted: Thu Nov 12, 2009 10:57 am
of course it should be from a carbed 900SS not a SSie
PostPosted: Fri Nov 13, 2009 1:15 am
Do you have a 6-spline or multi-spline crank on yours?
750 Paso cank-flywheel works w Kokusan.
I would download spare parts list f various models fr years like yours.
There are several parts that need to match,
f e w another flywheel, starter gear/sprag may be different.
Alternator is another issue.
PostPosted: Fri Nov 13, 2009 12:14 pm
PostPosted: Fri Nov 13, 2009 6:01 pm
PostPosted: Thu Nov 19, 2009 12:19 am
Thanks All for the tips.
As soon as I can get this sucker running properly again I will post some pics.
Joe
My Ducati Blog site
PostPosted: Sun Nov 29, 2009 7:28 am
Hello All,
I have a related question on the kokusan flywheel. There are serveral flywheels post 1998 on ebay. But I cannot find any pre 1998 flywheels. I have the 4 pickup flywheel.
What would be the feasibility of milling off the two upper pick-up points and leaving the two lower pickup points on the flywheel (as show in the maintenance manual when the #1 cylinder is at tdc)
I can locate another 4 pick-up point flywheel from a paso.
I have been running the 4 pickup point flywheel with the kokusan ignition and I think this could be causing my high speed bog.
Joe
My Ducati Blog site
PostPosted: Sun Nov 29, 2009 9:21 am
note the flywheel is balanced so removing parts will unbalance it causing vibration and some damage sooner or later.
PostPosted: Sun Nov 29, 2009 2:08 pm
I have 2 pre -98 flywheels f Kokusan to sell. Where are you located?
Do you have 6 spline or multispline crank?
Milling would need rebalancing to work as Gerhard states.
PostPosted: Sun Nov 29, 2009 11:44 pm
Hello Tabmurinfan
I have the 6 spline crank.
You can PM me with the price and shipping. I have a bid on a flywheel that paso750 found on ebay. If it does not go through I will more than likely purchase one from you.
Joe
My Ducati Blog site
PostPosted: Thu Dec 31, 2009 1:53 am
Hello All,
I changed out the old flywheel with the new one I purchased on ebay and that fixed my high speed miss.
So the Kokusan ignition change out was successful.
After all of the troubleshooting I went through it was really nice to get the bike running properly.
So I decided to tear it completely down and clean it up.
I did read a bit of interesting article on guzzitech.com on proper testing of the dual pickups.
Here is the link:
http://www.guzzitech.com/Bimotacagiva/P ... retch.html
I will be posting some pics of my progress.
Joe
My Ducati Blog site
PostPosted: Fri Jan 01, 2010 1:33 am
Great job & thx f sharing! :thumbup:
