It is currently Fri Oct 30, 2026 10:24 pm
 Post subject: ducati 906 paso ( 1990 ) cluster gauges , or dash bord
PostPosted: Fri Nov 27, 2009 10:00 pm
pls help , i'm from Romania and i just buy this superb motorcycle but it has no dash bord or cluster gauges , can annybody help me with some inos about where can i bui it?
thank you so much :)
 Post subject: Re: ducati 906 paso ( 1990 ) cluster gauges , or dash bord
PostPosted: Fri Nov 27, 2009 11:39 pm
http://www.marktplaats.nl/ , --> motoren, search f ducati paso.
I saw a dash today.
PostPosted: Sat Nov 28, 2009 12:30 am
thank you so much for the effort , but no english ?
i'm from Romania , i speak english , but nordic languages are a little bit hard for me
maybe can you help me?
eventually look for me? on this site pls?
PostPosted: Sat Nov 28, 2009 9:24 am
It`s from Holland so they speak Dutch.
But I don`t think that is a problem, Dutch people are usually very good at English.
Just press the link that says email on the right, fill in naam-name & het emailadres -your emaildaress &
what you want in the commentaar box.
I think that will work.
http://link.marktplaats.nl/292992145
PostPosted: Sat Nov 28, 2009 3:10 pm
thank you so much
PostPosted: Sun Nov 29, 2009 9:36 pm
Welcome Shaqy,
there is a new dash on ebay, now.
http://cgi.ebay.it/Ducati-906-907-Dash- ... 500wt_1182
Good luck :thumbup: :thumbup: :thumbup:
PostPosted: Sun Nov 29, 2009 9:57 pm
thank you so much :beer:
PostPosted: Sat Feb 20, 2010 12:16 am
i want to thanks all the great guys who try to help me , i finally buyed my dash bord for my bike , now i'm looking for something else , an carburator , Delorto :(
PostPosted: Sat Feb 20, 2010 9:14 am
If You are looking Dellorto's try to find 36mm ones, as 40mm are too big for 750cc engine. Keep in mind, that You need also then throttle cable systems and new accelerator handle. Another alternative is to find Mikuni's from mid 90's Monster or Supersport. Most expensive are Kehin flat slides and they are also quite hard to find from markets.I moved first from Weber to 40mm Dellortos but at the end changed to Mikuni's. You can find from here alot of info no matter what carburators You will put to Your Paso. Good luck! :thumbup:
PostPosted: Sat Feb 20, 2010 2:01 pm
I guess he needs the carbs for a 906 :mrgreen: :mrgreen: :mrgreen: :mrgreen: .
No matter, you can use the same Mikuni or Keihin for the later Ducatis as well as the 40's Dellortos.
Ciao :thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
PostPosted: Sat Feb 20, 2010 4:48 pm
Thanks Frankie :thumbup: 40mm Dellorto's are fine for 906.... seems that i have still too much shit from flu in brains! :banghead:
PostPosted: Sun Feb 21, 2010 9:41 pm
hi shaqu,
the dutch dashboard has no clock. the seller lives about 25 km from my place.
look on Ebay, there's offered a complete dash for € 60
http://cgi.ebay.de/Ducati-Paso-750-Vegl ... 5639c5daba
this guy is departing a P750.
I've dealth with him once and the sale went smoothly.
ducbertus
PostPosted: Sat May 01, 2010 12:18 pm
Thank you all for answers , and advices , :)
Best regards from romanian bikers :)
