It is currently Thu May 07, 2026 8:06 pm
 Post subject: Samco Hoses
PostPosted: Mon Dec 14, 2009 7:48 pm
Hi, I have searched about Samco hoses and there has not been a definitive answer if the 851 will rplace most of the hoses.
What about the ST2 set, there is no picture on the site,
http://www.samcosport.com/row/bike_kits.asp?make=Ducati
Anyone got further information before I try?
cheers
Nigel
91 907IE - full restoration
MPL Slipper,Ceramic exhaust
Lambretta LI150 S3
87 928S4
 Post subject: Re: Samco Hoses
PostPosted: Mon Dec 14, 2009 10:10 pm
I contacted them direct about a year ago and eventually got a reply, the result of which was they do not do a full set however if you vistied one of there main suppliers (that was here in the Uk to me) and took the Paso set to compare/match they may be able to assist. They also would not help when I even offered to send set direct to them and infact did not seem that interested in helping further :dunno:
As someone reminded me they are really there to support the race circuit set so if I want a set I will need to do all the donkey work and additional cost trying different sets to make a full matching set.
Let me know if you have any better luck because they are lush.
PostPosted: Tue Dec 15, 2009 4:25 am
After a fair bit of running around today , I think the best way is to fabricate an alloy or S/S piece for the two hoses that come off the main line, [a double' TT '] and also an elbow with a outlet to the coolant tank.
Then buy what ever elbows and straight pieces and join it all up, maybe also using straight alloy pieces, like a race bike set up.
Samco makes a flex hose that doesn't collapse so that may do some of the shorter lenghts.
I have made up my mind to do this , so I will let you know the outcome!
Nigel
Lambretta LI150 S3
87 928S4
