ducatipaso.org • View topic - 907 rings?
It is currently Thu Oct 02, 2025 2:28 am
 Post subject: 907 rings?
PostPosted: Fri Dec 18, 2009 8:11 am
Hi
I need a set of rings for my bike, Ducati Aust sell sets at AUD$370 per piston!
Any other suppliers out there?
Other option is FBF "Hi comp Drop in kit" at $420USD, but I don't think my insurance company would like that!
And I gather that I would also need to get a different chip for the bike at what cost????
FBF don't quote for custom chips
ta
Nigel
91 907IE - full restoration
MPL Slipper,Ceramic exhaust
Lambretta LI150 S3
87 928S4
 Post subject: Re: 907 rings?
PostPosted: Fri Dec 18, 2009 6:46 pm
Try these guys. They have the expertise, located in Atlanta, Georgia, USA http://www.ducshop.com. Or these guys in Yankeedom, http://www.easterncycleducati.com or http://www.bcmducati.com
All in USA. Here is one in UK www.cjsracing.co.uk
PostPosted: Fri Dec 18, 2009 7:11 pm
whilst trying to find rings for a 1930 ish blackstone diesel motor ,at the local motor reconditioner , I bemoaned the fact that I had to pay nz$600 for ducati rings , Turns out there is a subaru motor with 92mm bores and he could supply a 4 cyl set of rings for about nz$80 . I didnt follow this up at the time but this guy was confident that they would fit thickness wise and would suit a chrome bore................ might be worth a look
PostPosted: Sat Dec 19, 2009 6:42 pm
You can try these guys. they have most parts for Ducati http://www.ferracci.com/
PostPosted: Sun Dec 20, 2009 12:09 am
You can read through this site:
http://www.hastingsmfg.com
then email when w/your bore/stroke/cylinder wall construction/ring widths and they'll set you up...for probably less than 25usd per set. They'll be as good as OEM, if not better.
PostPosted: Sun Dec 20, 2009 12:14 am
Have you tried Gowanlochs in Sydney?
Jaffa
'91 907ie (RED)
'82 900 Mike Hailwood Replica
Volvo aware Motorcyclist
PostPosted: Sun Dec 20, 2009 1:55 am
Try these guys "http://www.munroemotors.com/" found some MIR fork seals on the self there.
PostPosted: Mon Dec 21, 2009 7:18 am
I inquired at Gowanlock's a couple of months ago for a set of rings for my 906 and they were going for about $280 per piston.
PostPosted: Mon Dec 21, 2009 9:24 pm
For that price, get a set of hi-comp piston that come with rings.
PostPosted: Tue Dec 22, 2009 1:35 am
Try JE Pistons. 92 mm bore ring set $27.00 US
PostPosted: Tue Dec 22, 2009 3:24 am
You have to make sure the ring widths are the same on the JE pistons as the Ducati ones. This isn't too hard to measure though.
A ring company like Hastings is going to be able to match up anything, if you give them bore, ring thickness and wall material. Deves is another reputable ring manufacturer, and they make a lot of European M/C rings:
http://www.deves.com/index.cfm
Sam
PostPosted: Tue Dec 22, 2009 3:28 am
One other thing - are you sure you need rings? Chrome rings (which I'm pretty the Ducati ones are) on a nickasil bore can last 100s of thousands of miles. Did a compression check show you needed them?
Sam
PostPosted: Tue Dec 22, 2009 11:20 am
Thanks for the replies!
I am leaning to the Hi Comp FBF [Ferracci] set at $420.
I have checked Hastings and woukld just need to get the mesurments from the garage.
The reason is that the rings are wrong, the oil ring is about 3mm too small, yep thats 3mm! rockers have flat spots and exhaust guides are very loose, So a full rebuild to now go with a complete restoration.
I ended up buying another 91 907 today with Jaffas fantastic help.
A rather tasty Xmas present!
Nigel
Lambretta LI150 S3
87 928S4
PostPosted: Wed Dec 23, 2009 3:50 am
Jaffa
'91 907ie (RED)
PostPosted: Fri Dec 25, 2009 9:15 am
Hi, I have a some sets of 92mm rings here in Sydney - Contact me if you are interested.
Mike
