ducatipaso.org • View topic - '91 to '97 ignition switch
It is currently Fri Jun 26, 2026 12:16 am
 Post subject: '91 to '97 ignition switch
PostPosted: Fri Dec 25, 2009 12:20 am
I've found a 91-97 Supersport / Superbike / Monster / ignition switch and I'd like to know if I can use it to replace my 750's switch. I don't have a problem splicing wires and all. I just want to know if there are any unforeseen issues I need to know about.
Thanks all . . . Ethan
'87 750 Paso 751412
 Post subject: Re: '91 to '97 ignition switch
PostPosted: Fri Dec 25, 2009 4:49 am
Ethan,
Many vintages of those switches have the same connector that was used on the Paso. If it looks the same, then it should fit. the mounting bolts are a bit different, but that can be overcome with a rattail file.
