ducatipaso.org • View topic - Any other ST series bikes owners in Ducatipaso.org sites?
It is currently Tue Jun 16, 2026 4:07 pm
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
 Post subject: Any other ST series bikes owners in Ducatipaso.org sites?
PostPosted: Thu Jan 21, 2010 4:19 pm
I have:
ST2 2001 (my "daily bike" currently) with some mods: FIM chip, Termignoni CF cans, STM clutch slave, STM 48 teeth alumium clutch with red pressure plate, CF open clutch cover, Steel braided brake & clutch lines, DD headlight, Polished wheels, Öhlins in rear with remote control for spring preload, Gear display, Heated grips, 2 extra 12v outlets for GPS, mobile etc., Spyball alarm, Halogen blinkers in rear with Kellerman electronic relay, Hazard lights, Sargent saddle, Heated grips, 5 Extra relays + 12 extra fuses, 10mm Bar risers, Z=14 front sprocket, side bags, top case, K&N air filter, Autocom PRO-7, Lower part painted to gunmetal, etc...
ST4S 2002 (for "fun") with some mods: 100Nm/6824RPM, 111Hp/8783RPM from rear wheel(inertia dynoed), new ECU with FIM data, K&N air filter, 748R springs in valve system, 2 x 12V outlets, Heated grips, Sprockets: front Z=14 / rear Z=41, Termignoni oval titanium cans / Sil Moto round CF cans, CF open clutch cover, 3 different saddles for different trips, Lower part painted to gunmetal, etc.. + all those "S" modell goodies (Öhlins in rear, TiN coated front fork sliders, Aluminium swingarm, 5 spoke Marchesini wheels, Immobilizer, Side bags, Steel braided all lines, etc..)
It would be nice to know other members STmodells / year, modifications here, as this is in "Off topic" section and free for such.... :thumbup:
 Post subject: Re: Any other ST series bikes owners in Ducatipaso.org sites?
PostPosted: Thu Jan 21, 2010 7:49 pm
I had a 98 which I spent 4 years modifying it, then finally went and got a 2002 ST4s. I try to take one long trip every year, and put about 5-6k on it every year. Mod list is: DD headlight, Dzus fasteners, 43 tooth rear sprocket (cause I can't find one bigger yet) CycleCat bars, heated grips, lowered pegs, 916 front fender, additional tail lights and turn signals, Ducati performance seat, Remus pipes. Coming this spring will be heated grips, Stebel Air horn, auxilary lights, and a spring tune up.
PostPosted: Sat Jan 23, 2010 4:22 pm
2000 st2 for easy riding
PostPosted: Sat Jan 23, 2010 5:20 pm
I would say, that better in all meanings compared to 907IE(Best Paso!), EXPECT taking fairings off :,( ... Its faster, more powerfull, better handling, better suspension, very realible, easy to maintain, better for long journeys, etc.... :smoke:
PostPosted: Sat Jan 23, 2010 6:32 pm
gee guys ! with all those mods you could hardly still call them dukes :D Wouldnt mind seeing some of those bits in my xmas stocking :mrgreen:
PostPosted: Sat Jan 23, 2010 9:06 pm
But the Paso is 10 times better looking..... :wink:
PostPosted: Sat Jan 23, 2010 10:39 pm
PostPosted: Sat Jan 23, 2010 11:01 pm
oh my god, the ST3 is so ugly :wacko:
PostPosted: Sun Jan 24, 2010 12:56 am
like all younger sisters, the ST is faster,better handling, more comfortable, less maintenance, etc. But true, she lacks the fiery good looks of her older sister. Shame they couldn't have graced her with better looks. But I end up choosing the younger sister over the older sister time and time again. But as Finnpaso points out, you got to do some work to get her clothes off. They both have a place in the garage.
PostPosted: Sun Jan 24, 2010 11:52 am
PostPosted: Sun Jan 24, 2010 12:03 pm
PostPosted: Sun Jan 24, 2010 4:03 pm
PostPosted: Sun Jan 24, 2010 4:41 pm
PostPosted: Sun Jan 24, 2010 5:06 pm
Here are facts: Modell, torque/rpm, power/rpm((crankcase/clutch), as it is different compared to power from rear wheel))
ST2: 82Nm/6500rpm 83Hp/8500rpm
ST3: 93Nm/7250rpm 102Hp/8750rpm
ST4: 84Nm/7250rpm 107Hp/9500rpm
ST4s: 98Nm/7000rpm 117hp/9000rpm
So, what can we see very simply:
*ST4 is just 916 engine swapped to ST frame, "high rpm engine"(like 916) with "same torque" as in ST2! U can get with ST4 only power in hig rpm compared to ST2!
*ST3 have more torque compared to ST2 and especially ST4, what means well planned engine from factory! But little less power than ST4 in top.
*ST4s have notable more torque compared to ST3 and its power is much higher than other modells.
* What rpm can get that best torque?
ST2 gives it lowest: 6500rpm, then ST4s is next 7000rpm and then ST3 and ST4 gives it 7250rpm So what? Thinking "easy use" it goes same way, ST2 easiest, then ST4s and those ST3 and ST4 needs MORE rpm for "easy drive" => something went wrong in ST3, as it needs so much rpm to get best torque! => compromise again from factory: there is good torque in ST3 but u can get it quite high rpm= not so easy for "normal drive", if dont want to keep rpm so high whole time.... max torque can be reach with ST2 750rpm lower than in ST3 and in ST4! Its alot! Everybody knows, that 916 engine(also ST4 needs MORE rpm to function well), as its "race engine" swapped direct from 916 to ST frame=>not so good combination!
These are my own conclutions from facts about torque and power.... For me that torque is much more important than max power, so for daily bike i choose ST2(easy to use) and if i need plenty of power, then i take my ST4s(plenty of power and torque) with very good suspension parts.
World is full of choises as everybody knows... :smoke: Nice time to everybody here with this topic :thumbup: :thumbup: :thumbup:
PostPosted: Sun Jan 24, 2010 5:15 pm
