It is currently Sun Sep 28, 2025 9:45 pm
[ 9 posts ] |
Author |
jpitz31
Post subject: Lower Triple Tree Bearing Posted: Tue Jan 26, 2010 4:37 pm |
Joined: Fri Aug 15, 2008 4:10 pm Posts: 84 Location: Escondido, CA
Anyone have any idea on how to remove the lower bearing and seal from the triple tree. It appears to be pressed on. I want to bead blast and powder coat the tree. But I am afraid that the heat will destroy the rubber seal.
Joe
_________________ 1990 Ducati 750 Sport (mine) 2007 Piaggio BV 500 (mine - daily driver) 2008 Piaggio MP3 500 (wife's)
My Ducati Blog site http://projectducati.blogspot.com/
Stupidity is not a crime, your are free to go
Top |
Post subject: Re: Lower Triple Tree Bearing Posted: Tue Jan 26, 2010 4:50 pm |
paso grand pooh-bah |
what rubber seal ? The seal is in the frame at least normally it is. I doubt there is any way getting the bearing race from the steering axle w/o destoying it. Trying to pull it off, hit it or heat it up may ruin it. I`d replace it.
Top |
jpitz31
Post subject: Re: Lower Triple Tree Bearing Posted: Tue Jan 26, 2010 5:16 pm |
Underneath the bearing there is a black aluminum looking spacer. The top bearing and seal came right off. By looking at the top spacer, there is a rubber seal on the inside of the spacer. I am assuming that the bottom spacer is the same. Looks like a dust seal.
To remove it do you suggest hitting it with a cold chisel and splitting the bearing?
I should clarify that I am using a 750 Paso triple tree on the Sport. There is thin aluminum wrapped around the fork legs to take offset the difference in fork diameter.
Joe
Top |
dtm79
Post subject: Re: Lower Triple Tree Bearing Posted: Tue Jan 26, 2010 9:05 pm |
Just one thing to add on getting the old bearing out the way .. I use a grinder to at least start the removal process after first wrapping up the stem and yoke .. but go easy . Haven't done one for a while but from memory it does seem to lessen the grip the old bearing has .. also put the yoke in the freezer over night .. should help the new brg go on easy ...
Top |
jpitz31
Post subject: Re: Lower Triple Tree Bearing Posted: Tue Jan 26, 2010 9:39 pm |
Sounds like a good tip dtm79
Joe
Top |
crmac
Post subject: Re: Lower Triple Tree Bearing Posted: Tue Jan 26, 2010 11:26 pm |
Only way I could get mine off was to use the angle grinder to cut through most of the bearing, then a cold chisel to finish it off. I previously tried hot, cold, chisel etc etc etc.
Top |
ducinthebay
Post subject: Re: Lower Triple Tree Bearing Posted: Tue Jan 26, 2010 11:45 pm |
Most of the time you can use a cold chisel to get underneath it, but sometimes its just too stubborn. I always assume that the bearing will be damaged, and plan on replacing it.
Yo, Joe, I gotta ask. Why are you using a set of Paso clamps on a Sport? The stock Sport clamps are just as strong as the Paso clamps, but don't have the silly ears for the bars. If you are going that far, get the forks too. Big upgrade from the stock M1bb fork. Ideal shim stock is stainless, or brass.
I have the Paso clamps on my Sport, but also have the M1R forks from a Paso. The fork stops work just fine, but the steering lock won't quite reach to work. (not that I need it)
Top |
jpitz31
Post subject: Re: Lower Triple Tree Bearing Posted: Tue Jan 26, 2010 11:57 pm |
Hey Phil,
The guy I purchased the bike from put the Paso triple and bars on as the sport clip-ons were bent. I have a complete set of 900CR triple clamps and forks that I will put on when the sport forks go.
They are not as nice as the 900ss adjustable forks but I got them on ebay for cheap.
Joe
Top |
ducinthebay
Post subject: Re: Lower Triple Tree Bearing Posted: Wed Jan 27, 2010 2:37 am |
Joe, You are headed in the right direction. I wouldn't wait for the Sport forks to die. Put that 900ss front end on while the snow is falling. then the switch to 17" wheels is as easy as bolting it all back together. but like any project, there's always that time commitment thing. (said the guy with a set of forks apart on his bench for a month now.)
Top |
[ 9 posts ] |
Users browsing this forum: No registered users and 0 guests |
