It is currently Thu Mar 05, 2026 12:32 am
| Author |
c-dogg
Post subject: newbie w/a 750, lots of questions Posted: Thu Sep 09, 2004 5:14 pm |
| Top |
Paul
Post subject: Repairing the fairing Posted: Fri Sep 10, 2004 10:44 am |
Joined: Fri Jul 16, 2004 12:00 am Posts: 187 Location: Hartbeespoort Dam, South Africa
| Top |
mach5er
Post subject: Posted: Fri Sep 10, 2004 12:26 pm |
Joined: Wed Aug 25, 2004 12:00 am Posts: 19 Location: Houston, TX
| Top |
bauhaus
Post subject: Posted: Fri Sep 10, 2004 7:17 pm |
| Top |
c-dogg
Post subject: Posted: Fri Sep 10, 2004 7:37 pm |
| Top |
bauhaus
Post subject: Posted: Sun Sep 12, 2004 12:34 am |
| Top |
Chilly_bill
Post subject: Posted: Mon Sep 13, 2004 8:44 pm |
| Top |
c-dogg
Post subject: Posted: Tue Sep 14, 2004 5:40 pm |
do you have the part number for that pump? manufacturer maybe. id like to try it
| Top |
jfiore
Post subject: Paso Quirks Posted: Wed Sep 15, 2004 4:59 pm |
Joined: Wed Jul 21, 2004 12:00 am Posts: 67 Location: Windsor, CT USA
| Top |
Chilly_bill
Post subject: clutch bleeding Posted: Fri Sep 17, 2004 2:43 pm |
Mike had recomended bleeding the clutch with the clutch cover off. I thought I had bled the system THOROUGHLY before and was still experiencing problems. As soon as I pulled the cover off one more air bubble came out and the clutch feels better than ever now.
Thanks Mike! :thumbup:
| Top |
jomo
Post subject: Posted: Wed Sep 22, 2004 12:14 pm |
Joined: Sun Jul 18, 2004 12:00 am Posts: 127 Location: Australia
With the clutch problem, go with the advice of chilly_bill. try different things, different angles, don't give up! I have spent hours trying to bleed the clutch and brakes. It would drive you to drink....and I don't need any extra excuses! I think one time I hooked up a pump full of brake fluid and pumped it in from the bleed nut, but it must be totally clean.
| Top |
manitoufs
Post subject: Posted: Fri Sep 24, 2004 1:55 pm |
Joined: Wed Aug 18, 2004 12:00 am Posts: 14 Location: USA
On the clutch -
I have a 1990 750 Sport. The o-ring on the slave cylinder needed replacement on mine. A Mityvac greatly simplifies the bleeding procedure.
George Betzhold
Scottish Woods Log Cabin Resort
Murphy, NC
| Top |
c-dogg
Post subject: Posted: Wed Sep 29, 2004 3:26 pm |
tried the clutch cover off method and it worked like a charm. at least it has so far. but after a week i think i feel the old clutch grimlins coming back. ill wait a while longer to see what really happens (i might try switching to mineral oil, as that might be the problem) and then try and bleed it again. do bubbles move around the system? i got the one out at the bolt, but maybe there were some smaller ones that have accumulated there again? i hope thats the case, because otherwise ive got a slow leak somewhere. i cant wait to try and track that down!
| Top |
Users browsing this forum: No registered users and 8 guests |
